Set endpoints on dumborc with f6g reciever
Hi.
Hi.How do you set the steering endpoints. Do you just use one of the twist dial under the lid? Also how about the throttle/ brake endpoints. Kraton 6s and just at replaced from the stock controller. This is my first RC
thanks!
thanks!
Manual transmitter -> EPA
Manual car -> ESC calibration
You will need to flip the trap door on the radio and read manual to find witch 1 of the 4 nobs adjusts end point epa...then turn that dial till you get what your after
I believe most Basic Transmitters that use knobs do not have EPA adjustments for steering. Your best bet would be to purchase a digital system that has all the desired features and adjustments.
The great thing about this is that you can transfer/expand the system to other vehicles as your collection grows by either moving or adding receivers.
