Serpent 750 Natrix
#121
#122
By “new pulleys”, do you mean the magnesium ones? Serpent really seems to be investing quite a bit in magnesium of late. On the topic of magnesium, Have you tried/tested the adjustable one way? I would especially love to confirm whether the approach is to tune the level of “drag” or braking achieved off power. I would imagine that it helps with the otherwise “rear wheel only” braking effect.
The new drag assisted one way diff allows you to adjust the amount of front braking power achieved by changing oil viscosity. Higher viscosity oils means more front braking power for lower traction conditions. Lower viscosity less for higher traction conditions. The lower you go in viscosity then the more out of corner drive and on throttle steering/change of direction you will have the trade off is less front braking power and so would not be ideal on tracks that have high speed approaches to slow speed hairpin corners for example requiring hard braking especially in lower tractions. My view is this is a thing to use in high grip and on fast/flowing tracks with lots of power on high speed turns and not for tight technical tracks.
#123
Thanks for the explanation, Dan. It seems the more I read up on the Evo, the bigger that list of upgrades parts gets, haha! Regardless, I’m excited for the release of this kit. Its announcement came literally days before I was going to start building mine.
I may just purchase the Evo and sell off my still in the box 750. Surely, whatever I may stand to lose will be less than what it would cost to even partially upgrade.
#124
#125
#126
#127
Thanks! Well - considering it’s still untouched in the box, it would be weird to build a car just for breaking in engines, lol. In either case, if I can recoup a good portion of the new car purchase with this, as any loss would certainly be better than what it would’ve cost to “upgrade” the 750.
#128
#129
Has anyone used the “drag assisted oneway” if so , what were your findings? A guy on FB said he felt it was a absolute must have!
#130
Check post #122 above...
#131
The 750 Evo is a really nice build. Feels & looks awesome on track.
First drive it had heaps of traction and fantastic rotation.
Love the active rear toe concept.
Can anyone advise on the variance from 'Static' toe when raising or lowering the link by one hole?
How many or what fraction of a degree does raising the link increase toe under acceleration / decrease under breaking?
Also, does ride height, shock/spring compression, shock oil or anti-roll bar thickness have any affect on the degree variance?
Cheers.
Cheers.
#134
Got the car out for the first time, compared to my 748 TQ the car seems up tot he task..
set up question:
Do you find that you need to add more caster to get on power and high speed sweeper steering ?
my instinct is the reduce front droop,
this is a medium to low bite track
set up question:
#135
Cheers.
Cheers.
I had the car out for the first time, i moved that rear active toe link up one hole, and could tell a measurable difference, I was able to come on throttle a little bit earlier , improving my exit speed
