Serpent 750 Natrix
#136
Hey there everyone, I ran into a problem during assembly of my kit and just wondering if anyone could help. I have found that the clutch housing and outer rim of the clutch are rubbing on the right side sway bar mount / brake disk mount that is bolted on...I’ve tried to get some pics but they are too blurry to show the problem.
Any help that can be sent my way would be helpful.
#137
Here’s a picture....the aluminum housing on the left and white plastic piece is what’s rubbing on the sway bar/brake housing.
#140
Suspended
The 3x5x1.5mm spacers belong between the brake caliper assembly and the part it mounts to, in the picture it looks like you just put them on the screws. This would be Step 19 in the manual.
The order is screw->804422->spacer->804426 it's a bit more obvious in the exploded view on page 49.
#142
Suspended
To me it looks like you put them on the screws directly, like you would with a washer, instead of between the two alu parts.
Here you can see the screw being flush with the first alu part:
While in your pic it looks like there is space in between:
#144
I have the 750 evo, car is nice, handles pretty well and the new 2 speed is super quick.
#145
Enjoy the building dude!
#146
Got the car out for the first time, compared to my 748 TQ the car seems up tot he task..
set up question:
Do you find that you need to add more caster to get on power and high speed sweeper steering ?
my instinct is the reduce front droop,
this is a medium to low bite track
set up question:
#147
Hello everyone, just wondering what you guys did when it came to routing your servo and battery wiring? I really don’t want to have to cut any of the wiring in order to shorten the leads but is that really what needs to happen?
Thanks for any help that can be sent my way....
#148
#150
+1 for the harness connector! I had this setup on my Impulse way back when, and plan to do the same on my EVO (which I still need to build).
A switch (mechanical or electronic) is just one more point of possible failure.
