X-ray XT8
#183
well.. after testing last night with the new aluminum parts.. the truck is faster and for sure has more cornering, and more speed through the corner.. and as windellmc said.. the rear end is alot more free than i like.. it will take a little bit of massaging to get it back how i like it..
i did a back to back.. didnt change anything setup wise.. i was faster in overall lap time.. but.. consistency was lower..
i couldnt get on the throttle as early as i could with the stock front end.. however.. the truck was much faster with the aluminum parts on it.
i gained about 0.8 seconds on fast lap.. my consistency went down due to not being used to the huge amount of steering.. i think some changes to the rear end will help in this..
overall.. very happy with the new parts.. on my fast lap with the truck.. it didnt even feel like i was driving that hard.. alot of that is my driving style though.. friend of mine even was suprised with the time i put..
#184
what part number xt8e 2018 e-truggy not 2017 thanks
#186
How much would it cost to convert a nitro to ep
#188
Here is the direct way to get an electric version. https://www.absolutehobbyz.com/searc...50203+&search= It is $649 compared to the nitro $639.
#189
#355083 Extreme Heat Resistant Center Diff Pin with Inserts (2+4)
• Increases lifetime
• For extreme heat conditions
• Smoother run
• Precision ground
• Steel inserts
Precision-ground polished steel pin 3.5 x 33 mm for internal satellite gears used in large center differential #355013. Mounted in steel inserts instead of directly mounted in differential case increases the lifetime, especially in high temperatures. Set of 2.
Fits: XB8'17, XB8'18, XB8E'17, XB8E'18 & XT8'17.
• Smoother run
• Precision ground
• Steel inserts
#192
RCAmerica has updated their website, go check it out. you can search any parts by number if you cant find them in the drop down menus.
It also has stock status of parts, so you can be sure they will be shipped to you.
https://www.rcamerica.com/
#195
