Like Tree24Likes
Sworkz S35-3
Old 04-23-2018, 01:09 PM
  #121
Originally Posted by rickster
Hi flat7.... no you would be fine using your evo 2 towers... they are a little shorter then the 353 and a little wider at top... if you run inside first 3 holes its similar geometry as new towers.... if you run more outside holes it stands shock up more and will quicken steering response... you can limit travel to offset tower height... the 353 has a different pill insert setup then the evo 2 tower... but both will work fine. hope that helps.
Thanks!
flat7 is offline
Old 04-26-2018, 06:58 PM
  #122
no problem... glad to help.... I actually like the evo2 front tower on my 353 on tighter tracks... I also on bumpy tracks run the older lightweight cva's in the front with the evo2 front hubs and bearings... I use the lightweight +1 hexes for a little wider front and it makes the car stable and corner better especially if the track is a little bumpy or choppy. don't be afraid to mix some parts as you may have a better handling car for it.
rickster is offline
Old 06-20-2018, 07:09 AM
  #123
tom1974's Avatar
Where i can buy sworkz parts in usa or Europe?
differential front/rear SWX-210081
thanks
tom1974 is offline
Old 06-20-2018, 07:43 AM
  #124
ROSCOE's Avatar
Trader Rating: 130 (100%+)
thanks
https://www.amainhobbies.com/sworkz-...81/p696339?r=0
ROSCOE is offline
Old 06-21-2018, 09:12 AM
  #125
tom1974's Avatar
Ok thanks
tom1974 is offline
Old 07-22-2018, 06:37 AM
  #126
So how is this buggy going any more updates on it what's it like to drive now since been out for a while
MadMick is offline
Old 09-01-2018, 09:27 AM
  #127
mebolson's Avatar
Trader Rating: 41 (100%+)
If anyone wants a killer deal on a new S35-3e...
New Sworkz S35-3e E-Buggy, assembled, custom, with spares! ( ebuggy sworks s353e)
mebolson is offline
Old 09-15-2018, 01:48 PM
  #128
Default Sworkz 35-3
Hello guys I can’t get the rearend To settle down! Wants whip around corners and I loose traction ! Need help !
mugen boi is offline
Old 09-20-2018, 08:30 AM
  #129
andry_k26's Avatar
Hello everyone, I wanted to ask! On my buggy sworkz s35-3e wedges steering at maximum angle of rotation. Maybe someone had such problem ?
andry_k26 is offline
Old 09-27-2018, 04:36 AM
  #130
Make sure you run some weight on the back end... Big difference in rear traction.
PeterEd is offline
Old 09-28-2018, 10:27 PM
  #131
Trader Rating: 79 (99%+)
Definitely weight in the rear..and stiffening the chassis simultaneously.
Raul Garcia is offline
Old 09-29-2018, 03:10 AM
  #132
If the car needs weight to run right then it's too stiff. Softer springs give more grip up to a point, at that point a stiffer roll bar would increase grip even if that sounds counterintuitive.
Or the rear end geometry isn't right, I could take a look if someone wants to have a go.
30Tooth is offline
Old 10-02-2018, 07:28 PM
  #133
Thanks ill try that. I already added weights and that help a little bit..
Old 10-02-2018, 07:30 PM
  #134
Thanks i already added 30gms of weight , might need to add more ....
Old 10-02-2018, 08:10 PM
  #135
do you also have the brass hinge pin mounts?
