Hotbodies D817 Nitro thread
#391
#392
#393
It seems kind of funny that HB came out with the E817 buggy in January 2017 and then did not release the D817 buggy until April 2017 and now HB is coming out with the V2 upgrades to the D817 first before the E817?
#394
New nitro specific parts:
• NEW 7075 aluminum chassis
• NEW Aluminum center bulkhead stiffener
• NEW Updated aluminum flywheel
• NEW O-ring brake linkage spacers
General '817 series' parts:
• NEW Strengthened aluminum 17.5° caster blocks - V3? revised 15° and 20° options too?
• NEW Aluminum front linkage spacers - possibly orange using their existing parts bin...
https://www.amainhobbies.com/hb-raci...112797/p298447
• NEW Molded nylon rear wing - Can already get a this part now in a number of colour options...
• NEW JConcepts Silencer buggy body - could be used on the ebuggy as well
• NEW Narrow rear shock tower
• NEW Revised rear shock length (+5mm)
The E817 chassis already has plenty of chassis bracing from the get go; lesson learned from the tekno v4 conversion prototypes...
What other improvements do you think the E817 needs? I'll be getting some of the part individually...
Aside from the above, there may very well be an E817 V2 coming...
I suspect the revised bracing on the nitro is HB Racings answer to carbon fibre/alum radio tray stiffeners currently used.
#395
Some new part #
HB-204272 HB D817v2 1/8 Competition Nitro Buggy
HB-204250 HB RACING Aluminium Throttlle Servo Horn (25T) D8 Series
HB-204253 HB RACING Aluminium Throttlle Servo Horn (23T) D8 Series
HB-204262 HB RACING Aluminium Steering Servo Horn (25) V2 D8 Series
HB-204263 HB RACING Aluminium Steering Servo Horn (23) V2 D8 Series
HB-204268 HB RACING Caster Block Set V3 (15 degree)
HB-204269 HB RACING Caster Block Set V3 17.5 degree
HB-204270 HB RACING Caster Block Set V3 (20 degree)
HB-204322 HB RACING Flywheel V2 3pins, Hard black
HB-204324 HB RACING Rear Shock Tower V2 D817V2-E817V
HB-204260 HB RACING Bearing 8x16x5mm V2 (2pcs)
HB-204340 HB RACING O'Ring 2x5.36x1.8 (8pcs)
HB-204326 HB RACING D817V2 Buggy Bodyshell (Jconcept)
HB-204342 HB RACING Rear Shock Kit V2 D817V2-E817V2
HB-204341 HB RACING Front Shock Kit V2 D817V2-E817V2
HB-204325 HB RACING Chassis D817V2
#397
Hi, been having issues with idle settings but I think I have it settled on LRP .30 Spec 3. My major issue is that I have 2 LRP motors .28 and .30 the spin start is different on them. The nut on the back is different on them. One is 3/8 the other is 7/16. The smaller one has stripped, rounding off the corners. Any help would be great.
#398
I sold my TLR 4.0 to get into electric and the HB E817 is what I plan on getting. I assumed if the nitro is getting a face lift then it only stands to reason the Ebuggy would get one. Don't know if it needs any improvement. (I've heard nothing but good things about the ebuggy.) But, isn't the E817 the first 1/8 Ebuggy developed by HB? Also since it's raining and there's no 1/8 racing I might be better off waiting to see if the E817 gets the v2 upgrade before I buy.
#399
#400
#402
#403
#404
High tower
Just a heads up with the V2 tower and shocks, the only part you need to change in the shocks is the plastic shock end. This needs to be the end from the old D8T part number 67820.
#405
