Agama A215T
#106
i know to use the droop screws but with everything being equal the arms should be drooping to somewhat the same level. the way it is now one droop screw would be just barely feeding through the arm to touch the chassis and the other would be almost all the way through to bring the arm up to the same droop as the other side.
your rear clip is not on the chassis properly or the shock end is on backwards stopping the arm from dropping all the way down. post a pic and we can diagnose quickly.
#107
the only thing I could think of is there is a bind somewhere that lifts the one side when the other side is lifted. or the sway bar is too tight or too hard. but this may be the case since based on your post that both droop screws touch the chassis.
on this truck my max droop setting is just enough to reach the full travel of each shock.
#108
all brackets are seated onto chassis correctly. diff housing is seated correctly onto brackets/chassis. shock ends are on correctly. checked all measurements a million times and i still get the passenger side rear arm to hang 3.5mm lower than the drivers side rear arm.
sure i can get both sides to droop equal using the droop screws but i would think both sides would be closer than 3.5mm difference without using screws. if you back your droop screws all the way out and have the shocks still connected. will your arms droop low enough to touch the chassis or does the shock length hold them up off the chassis? without using your droop screws, whats the difference in droop you have side to side?
#109
Measure your shocks. Make sure they are equal. With shocks off, test arms. Lift both sides up and they should move smoothly and drop. If not, you've got a bind. Now set your droop with out shocks. Do the same test. I have noticed that the droop screws gets stuck and don't settle in the grooves correctly, leaving one side higher until I press down.
#110
all that checks out ok. cant really set droop with the shocks off cuz once i install them the droop will be wrong. the shock length does not let the arms fall all the way to the chassis. thats why i asked if everyone elses arms touch the chassis with the droop screws backed out. (using middle hole on both arms and shock tower)
#111
Full droop (screws backed off completely), middle hole in tower and arm my arms don't rest on the chassis. Shock length/droop is 127-128.
#113
Hey guys anyone have a good all around set up to run on the truggy.
#115
Either 7/10/3 or 10/10/3 in diffs depending on traction and steering. 37.5 8-1.3 in front and rear. Middle hole on tower inside hole on arm for front shocks middle on tower and arm for rear tower. And run the camber links middle inside hole on tower inside hole on hub. Mid or lower inside hole on tower and all the way out on upright for the rear.
#116
TQ, Win and 3rd at the 11th Rhein Main Warm-Up race for the A215T
#117
Where r u guys putting your transponder at.
#119
Battery Box
#120
What pinion are you guys running on the Etruggy?
