-   Nitro Off-Road (https://www.rctech.net/forum/nitro-off-road-130/)
-   -   Agama A215T (https://www.rctech.net/forum/nitro-off-road/964964-agama-a215t.html)
Barracuda72 10-14-2016 12:54 PM
Agama A215T
Finally the new Truggy A215T is comming soon
News on Neobuggy
I dont like the Body..hope it looks live better than on these pics.
Keith B 10-14-2016 01:11 PM
News on Neobuggy
Revisions to the 1st up. I get it.:o
Barracuda72 10-19-2016 06:09 AM
Got my A215T Kit today..first in germany..without manual..
like my old A9T and my A8 and A215...
Agama A215T
Keith B 10-19-2016 07:48 AM
Agama A215T
Hooray chaps. :mad:
Warrenvd 10-19-2016 09:27 AM
Agama A215T
Should be able to build it off the A215 Manual.. ;)
dakilo 10-19-2016 10:25 AM
A215T
What all changes did they do,intial pics show updated brakes, steering rack and battery tray.
Agama A215T
pword 10-19-2016 10:43 AM
electronics assembly - fixed
brake system - fixed
steering system - fixed
wider chassis - fixed
probably comes with longer front shocks to allow more down travel/droop and better steering.
ROSCOE 10-19-2016 11:25 AM
Based on the pics is it safe to assume the truck tail of the chassis isn't kicked up like the buggy?
ROSCOE 10-19-2016 11:32 AM
Looks like new hinge plates throughout with more adjustability in the insert.
Sideshow Bob 10-19-2016 09:08 PM
it should as far as i know. the prototype our guys tested definitely had a kink in the rear too.
http://i264.photobucket.com/albums/i...j.jpg~original[/URL]
Barracuda72 10-20-2016 06:13 AM
And the final Version too ;)
IŽll start building it at the weekend..so some first impressions and changes i noticed:
Steering is now the a215 Standart ( changed it some time ago on the A8t already)
Radio tray...Yeah..enough space for a big 3000mAh Lipo
Brakes..Ferodo is now standard
on the Rear on the chassis plate there are some aditional holes. 2 of them u see on the pic above..for aditional weights..sure..truggy iss so light..
and 2 more holes inline with the two holes for the chassis brace. You can mount the brace from e-buggy. Had serious probs with too much chassis flex on the A8T when racing on astroturf or high grip tracks like indoor at the Leipzig toy fair.
You still can mount the optional lower engine mount plates but friend made a nice quick change engine mount, so i must use the short plates.
shock tower are slightly different.
A-arms..same shape but different coulor( material?)
..will update this when i start build it
Barracuda72 10-23-2016 09:38 AM
today i started to build it.
Center diff..due the bigger spur gear they choose the way to use a alu spacer under the middle differential. secured by an extra screw and nut.
A-Arm have the same shape as the old truggy but now they are about 5mm longer and the new grey material is much stiffer.
the whole truggy is noch about 1cm longer than the old one.
CHASSIS
rear axle was easy to build. the new hinpin inserts allow more choices than the old one.
in the Moment i have probs with the front. the CVD will bind if the arm are in very low or high position..as the cdv are some mm too long. maybe just a prob with the wrong setup with the inserts.
Arms UP
arms DOWN
another prob were the steering posts. on old chassis there were some millings where the fit in. at the new one there are no millings.
Barracuda72 10-23-2016 10:18 AM
ok..just chatted with Mark Rumble from Nemo..the missing milling at the steering posts..the new chassis is 1mm thinner so if there would be millings like the old one the whole steering wouldnt fit
Sideshow Bob 10-23-2016 10:18 PM
Its the same on the 215 buggy..its so that you can get n flat hex wrench ( aka hudy wrench) in there to hold it in place so you can tighten them or undo them properly without worrying about stripping out the screws - a propblen on most cars in this area since you have to threadlock these usuallt
Barracuda72 10-24-2016 06:04 AM
just wondered about it..because i rememer the milling from the old A8T..and as its a pre retail kit i just wanted to be sure, that the chassis is ok..shit can happen...
Powered By: vBulletin v3.9.3.6
