Serpent SRX-8 Nitro buggy
#826
Wow, what a deal! Considering how much winyou got with that purchase, you really should splurge and buy yourself those blinged out aluminum chassis braces, Ha!
#830
Any of the new parts for the Pro car start with a 601 part number. So if you go through the manual you will find them in there.
Example, the new diffs
FR/RR Diff SER601068 - https://www.serpent.com/xcart/cart.php?target=product&product_id=10849
Center Diff SER601069 - https://www.serpent.com/xcart/cart.php?target=product&product_id=10850
Rear Wing Mount SER60166 - https://www.serpent.com/xcart/cart.p...oduct_id=10847
#834
Piston size it is the stock one 6 hole 1.2mm, 500CST front and 300CST rear. Ride height 25mm F/R
For the stock setup you use the SRX EVO default setup. The only changes are on the diffs which are 5k-5k-3k
The steering linkage changes from 11mm to 9mm, but this is part of the manual.
#835
#837
it comes with a USB for the manual. Or you can get the pdf through the Serpent site.
I printed the manual and placed it in a binder. At the same time I printed extra setup sheets in order to take notes or any changes made
#839
#840
Yes I have it on my phone as well (which is a nice way of having it right there), at the same time I enjoy flipping pages and not stare at a screen. I find it easier to complete the setup sheet with a pen. When I get home and have a moment I transfer that to a setup sheet on the PC and print it out.
