Kyosho Inferno MP9 TKI4 1/8 Buggy Kit
#572
Does any one know how to build a 4 piece clutch from nova Rossi I'm trying to get it on my p5xlt I also brought there fly wheal any one know how to fit them every time I try and put the shoes on the flywheel there loose.
#573
#574
This happend me two times last year. On time in the Norwegian cup amain :-( If the hingepin is snug in the rear arm insets it will happend. Use a 3.1 mm drillbit and free up the inserts. Then use a 3mm washer between the rear arm and the locknut.
#575
You will have to "push and turn" the center hat into place. You'll feel the springs engage; turn it counter-clockwise and it will set itself into place as you push the center hat down onto pins.
Its the same method as Reds & Werks. Werks had a handy little tool that helps. May can find a pic or video of it.
#576
Kyosho MP9 TKI4 euro champ with Boots!
Good driving and congrats!
#577
Which wing height on the tki4 a,b,or c give more low speed rotation into the corner
#578
I think its the higher mount but cant remember
#579
kick up
Does anyone know how much kick up the new tki4 B block takes out of the front end ? I would like to try a comparable setting with the tki3 part I have if its possible and see if I like the change. My track isn't " smooth , super high grip" like the new kit seems to be geared towards , but it does groove up nice and is not rough or bumpy ....
FWIW , Do any of the new parts create geometry that isn't within the adjustment limits of the current car ? Is the new ackerman angle not within the current cars adj range ?
#580
#582
Is there any other clutch bells that work with the stock flywheel other than Kyosho?
#585
