TLR 8ight 4.0
#1306
#1307
Since I can’t drive right now I guess I will share something that has made my car a lot better, the new disk brakes in the tuning kit has made my buggy a trillion times better on braking, no more fade and best of all they are smooth instead of pulsating. My worry was they would be on off feeling but that’s not the case, they are buttery smooth and will stop u immediately if u need to, best of both worlds.
#1311
#1313
I doubt Losi will switch to a pillow ball system.
#1314
I would suggest you try like Blue front and yellow or orange rear.
Green, Blue and Purple fronts are popular and yellow, orange rears
You will also need PN: LOSA5435 in order to run the bigger spring.
There is also a video on https://www.facebook.com/TeamLosiRacing/ where the team manager talks about these parts - go check it out...
#1315
Here are the part numbers for the springs and the universal set up.
Evo Front Springs:
TLR344016-4.5 Orange
TLR344017-4.7 Yellow
TLR344018-4.9 Green
TLR344019-5.1 Blue
TLR344020-5.3 Violet
TLR344021-5.5 Grey
Evo Rear Springs:
TLR344022-3.6 Brown
TLR344023-3.8 Red
TLR344024-4.0 Orange
TLR344025-4.2 Yellow
TLR344026-4.4 Green
TLR344027-4.6 Blue
TLR344028-4.8 Violet
Spring Cups:
LOSA5435- Shock ends, Cups, Bushings
Long Universal Setup (Front & Rear):
TLR344006- Front Universal Spindle set
TLR344008-Rear Alum Adjustable hub
2x TLR342010- Front Universal Set
Servo Saver Setup:
TLR341004- Clamping Servo Saver Nut
#DriveTLR
Evo Front Springs:
TLR344018-4.9 Green
TLR344019-5.1 Blue
TLR344021-5.5 Grey
Evo Rear Springs:
TLR344022-3.6 Brown
TLR344023-3.8 Red
TLR344026-4.4 Green
TLR344027-4.6 Blue
Spring Cups:
Servo Saver Setup:
#DriveTLR
#1317
night and day difference if you ask me. Im currently running Renos shock package and I do like it. purple front and yellow rear.
#1319
Front center dogbon replacememt
Wanted to replace front center driveshaft dogbone and maybe the outdrive. Best way to tackle this?
#1320
No jeed to replace the entire dogbone instead get the mugen pin replacement tool (mugb0541) and some mugen pins (mugc0271 or mugc0270). Works great and can be used on all drive train parts. As far as the outdrive (tlr242003) that will need to be replaced every so often ive found that the front wears a little faster than the rear. Just take of the front clip to get easy access to both the outdrive and dogbone.
