Associated RC8T3
#736
Looking at the setup sheets from the pros. I don't see anything that says droop length? I do see shock over all length, is that the droop setup?
#738
#739
Question for you guys that have had the truggy for awhile . What fix do you guys use on the rear tie rods? I have taken the truck to the track 3 times now and I still haven’t been threw a tank . What have I done wrong? Truck feels good but I haven’t finished a qualifier yet because the tie rod ends pop off . I tried mugen ends and same outcome do I need a new tie rod?
#740
#741
I have a set with set screws I added. and shoe goo inside. No issues.
#742
Hope this helps.
#743
I use the newer ends with Lunsford rods and have had 0 issues. When I used the older version ends I used CA . Never experienced older rod ends pulling off the Lunsford's, but used it as a precaution.
#747
Lots of changes. v3 diffs, arms are a touch different, A,B,C,D, blocks, new front upper arms , CVA's .
AE has updated parts along the way without notice. The steering Plate is now solid and un machined so it doesn't bend. The differential gear cases are harder to minimize case wear and notching, some plastics have been updated for more support. The gear boxes/shock tower supports are also reinforced to reduce flex and more consistent mesh.
#748
Just wondering, but why no FT carbon towers for the T3?
#749
#750
