Associated RC8T3
#751
#752
#753
Anyone know where I can get some new HB orange rear springs. I need a new set but cant find them anywhere
#754
Question for those running the SWorkz a-arms. Are they all direct fit? If not, what else needs to be changed?
#756
Hub down (hinge pin in upper hole) gives better forward bite and more rear traction out of a corner. Generally used on low grip or when you need more stability. Hub up is supposedly better on high bite tracks but I find myself running the hubs down all the time.
#758
#759
Ongaro's DNC setup is up. I don't think I'll be brave enough to try it. https://www.teamassociated.com/pdf/c...Ongaro_DNC.pdf
#760
Interesting! Thank you for sharing that. Don’t think I could go back to HTC gears and 15-15-10 after using the LTC gears and 15-20-10. It has been a good set up the last couple tracks I have been at.
#761
The lack of any toe in and full anti-squat is what I don't get. I don't think mere mortals could drive his setups. It can't have any sort of rear grip. All rotation, all the time.
#762
#763
The bigger rear sway bar and no toe get it to turn off power, and keep it from pushing on power... the thick front and center probably gave him the drive off the corner and acceleration he needed.
#764
I agree. There is not any cushion on that setup at all....it is a qualifying lap every lap
The front pills are what get me. Opposite of what I believed for rough track.
