Tekno NB48.3 Thread
#136
#137
Anyone try different shock piston than 4 x 1,8? Also your opinion why Tekno decide to use this configuration
#138
I haven't had any issues with them. If you are still using the old chassis on your NT48, getting the gear mesh right is very important. The new chassis/spur combo is supposed to have corrected the problem, but I have not changed over yet.
#139
Thanks. I have the new chassis. Most of the bell tooth wear came w/M2C chassis. May not have had it lined up perfectly. Anyway, since the 5x11x5 bearing is supposed to be more durable, I'll give the stock bell/bearing a try. If that doesn't work out, I'll try the Lutz clutch bell. Thanks for that info. I didn't even know they sold things.
#140
#142
Agreed. As much as I love Tekno, I haven't found anything better than TKO clutch bell bearings. It's been my experience that the 10mm TKO is much more durable than the 11mm Tekno bearing. But that's just me.
#143
Itching to play with the universals... Should I order the mbx7r (92.5mm), mp9 (91.5 or 93mm), or keep waiting for the tekno ones...?
#144
#147
#148
