Proline Buggy Tire Help
What Proline 1/8 Buggy tire should I be using on a low traction, loose dirt track that does get watered? Some people use AKA I-Beams? No one at our local track uses Proline so am after some advice.
Thanks everyone for your help, I want to use pre mounts and see the bow tie 2.0 only comes in x2, x3 & x4. If I went with x4, how does this compare with m3? The temps here would be around 20 degrees Celsius.
I would suggest the Suppressor or Blockade M3. I only run the X series for long mains in heat.
