Agama Racing A215 Buggy
#1217
Out of the box the car is good, no upgrades needed , I do recommend picking up some extra suspension adjustment "pills" as the car only comes with enough to build it
There are a few setups posted on the Nemo USA website , start with the " base " setup listed except run the inside hole on the front caster block opposed to the outside hole.
#1218
and 1.3 x8 pisons perhaps. thats it.
#1219
and the 4819 Option brake set...
#1220
I've ran the car stock for a year and 4 months. I haven't seen where anything is needed other than some adjustment pills and I would grab the 6-hole, 1.5 pistons. This really helps the car in the rough and simply allows the car to work better. I have a very easy to drive setup that gives good traction and corner speed. Get in touch if you need help.
#1224
#1227
If they are dragging, just loosen them a bit. I have never used the measurement...
Also, make sure you aren't use the little rotor guides that attach to bottom of diff holder. Old obsolete parts that I wish weren't even in the kit.
#1230
2x out, as they seal from dirt outside and alu dust inside..
