widfire nirto probs(no throttle when press handset) >
Old 07-23-2014, 12:23 PM
Default widfire nirto probs(no throttle when press handset)
hi there guys I really need some help,
I just got a wildfire nitro car with 15cxp engine and all worked fine when I picked it up from boy but when got home it started ok but wouldn't work throttle of handset. steering works fine but no brake/throttle, changed battery's and checked connections but nothing
please help.
could it be the servo?
a9racer is offline
Old 07-23-2014, 03:14 PM
rustyfingers's Avatar
Watch the throttle servo when you pull the trigger. Does it move?
No, check servo connections to the receiver first but could be bad throttle servo.
Yes, check the linkages from the server to the engine and brakes. Does the throttle servo center when you turn on the car?
To check the transmitter trigger move the throttle servo to the steering input on the receiver. It should move the wheels when you pull the trigger.
rustyfingers is offline
