Good temp guage?
Hi Guys, I'm just wondering what any of you guys think a good temperature guage is? As i have a losi one and i feel it's taking a dump on me. So I figured it was time to get a new one. Thanks in advance!
Originally Posted by gt racing
(Post 13067024)
(Post 13067024)
You don't need anything too crazy, and accuracy can be +\- 5 or so degrees with no problem at all, it's just to get an idea really. Lots of guys around here (Myself included) use this Trakpower http://www.towerhobbies.com/products.../tkpp9000.html Not too big and has a lanyard\stopwatch for your pit guy to keep track of fuel stops etc. |
Originally Posted by Bigwave
(Post 13067035)
I hope that was a joke :eek:
(Post 13067035)
You don't need anything too crazy, and accuracy can be +\- 5 or so degrees with no problem at all, it's just to get an idea really. Lots of guys around here (Myself included) use this Trakpower http://www.towerhobbies.com/products.../tkpp9000.html Not too big and has a lanyard\stopwatch for your pit guy to keep track of fuel stops etc. I've compared mine to many different budget friendly temps guns, like the one you have in the link. I've seen differences as little as 5 degrees, to as much as 40 deg. The low cost ones have consistently read lower than the Exergen. I've also sent mine in for calibration twice.....both times there was no changes needed. For nitro, even if you're only keeping track of temps at the end of a race to make sure it's not getting too high, there's a big difference between 250F and 290F. On the flip side, it's not just for nitro either. If you want to make sure your electric equipment is running at peak performance, you need to have accurate temp readings on the motor and ESC. The folks who don't care much about equipment temps will never be convinced that spending close to $200 for a temp gun is worth it. For the folks who believe in keeping accurate measurements, nothing else but an Exergen is acceptable. Just an FYI though, the Trakpower (formerly O'Donnell branded) temp gun has consistently been the farthest off from the Exergen (generally reading between 20 and 40 degrees lower). The TG1 from tempgun.com has been the closest (generally within 5 degrees F). I have one of those in my tool box as well, just in case something happens to my Exergen. (Here's a link to it) |
Total BS
Ok some of the cheap rc specific temp guns are not good but I would not pay over 200 dollars that's just silly. I use these and they work great.
http://www.ebay.com/itm/Non-Contact-...item2ec7b7ca37 |
i got one of these
http://www.ebay.com.au/itm/Non-Conta...item1e85c5704b i've tested it against a fluke temp gun and reads similar temps. |
Originally Posted by Stubbs
(Post 13067312)
No, that wasn't a joke......if you want to keep really accurate tabs on your equipment, nothing beats the exergen. If you look around, you can get them for much less than $270. I paid $180 for mine, brand new, about 5 years ago.
I've compared mine to many different budget friendly temps guns, like the one you have in the link. I've seen differences as little as 5 degrees, to as much as 40 deg. The low cost ones have consistently read lower than the Exergen. I've also sent mine in for calibration twice.....both times there was no changes needed. For nitro, even if you're only keeping track of temps at the end of a race to make sure it's not getting too high, there's a big difference between 250F and 290F. On the flip side, it's not just for nitro either. If you want to make sure your electric equipment is running at peak performance, you need to have accurate temp readings on the motor and ESC. The folks who don't care much about equipment temps will never be convinced that spending close to $200 for a temp gun is worth it. For the folks who believe in keeping accurate measurements, nothing else but an Exergen is acceptable. Just an FYI though, the Trakpower (formerly O'Donnell branded) temp gun has consistently been the farthest off from the Exergen (generally reading between 20 and 40 degrees lower). The TG1 from tempgun.com has been the closest (generally within 5 degrees F). I have one of those in my tool box as well, just in case something happens to my Exergen. (Here's a link to it) The cheap guns are ok to get an idea of the temps but will never be as accurate as the Exergen. Sorry chaps it's a fact! |
Thanks for all the input guys
I also recommend the Duratrax infrared sensor. It's pretty cheap and really reliable. It's also quite accurate.
The flukes good enough for me. 270 seems a bit much for the excergen. Maybe because they are into medical equipment?
The cheap ones are all inaccurate and the exergen is just too expensive. The best test you can do it temp boiling water. I think its 202 degrees. You will know instantly how close your gun is. Someone really needs to release a good accurate gun in the $75-$100 price range. They would be a great seller.
Surprised there isn't a HK version of the exergen...
Originally Posted by HomicidalBunny
(Post 13069093)
Easily good enough for getting a reasonably accurate temp from my nitro engines.
Originally Posted by Jaz240
(Post 13069278)
Hey ozziii are you coming to the AKA Hi Impact Duel at CORMCC on the 8th and 9th of March?
(Post 13067312)
I've compared mine to many different budget friendly temps guns, like the one you have in the link. I've seen differences as little as 5 degrees, to as much as 40 deg. The low cost ones have consistently read lower than the Exergen. I've also sent mine in for calibration twice.....both times there was no changes needed. For nitro, even if you're only keeping track of temps at the end of a race to make sure it's not getting too high, there's a big difference between 250F and 290F. On the flip side, it's not just for nitro either. If you want to make sure your electric equipment is running at peak performance, you need to have accurate temp readings on the motor and ESC. The folks who don't care much about equipment temps will never be convinced that spending close to $200 for a temp gun is worth it. For the folks who believe in keeping accurate measurements, nothing else but an Exergen is acceptable. Just an FYI though, the Trakpower (formerly O'Donnell branded) temp gun has consistently been the farthest off from the Exergen (generally reading between 20 and 40 degrees lower). The TG1 from tempgun.com has been the closest (generally within 5 degrees F). I have one of those in my tool box as well, just in case something happens to my Exergen. (Here's a link to it) I don't mind spending money but that's just dumb, The Milwaukee 2265 is in that price range of $80-$100 and just as accurate as that $280 model actually they are both have around within 2-3% accuracy and you save $200 for a hooker |
(Post 13067312)
I've compared mine to many different budget friendly temps guns, like the one you have in the link. I've seen differences as little as 5 degrees, to as much as 40 deg. The low cost ones have consistently read lower than the Exergen. I've also sent mine in for calibration twice.....both times there was no changes needed. For nitro, even if you're only keeping track of temps at the end of a race to make sure it's not getting too high, there's a big difference between 250F and 290F. On the flip side, it's not just for nitro either. If you want to make sure your electric equipment is running at peak performance, you need to have accurate temp readings on the motor and ESC. The folks who don't care much about equipment temps will never be convinced that spending close to $200 for a temp gun is worth it. For the folks who believe in keeping accurate measurements, nothing else but an Exergen is acceptable. Just an FYI though, the Trakpower (formerly O'Donnell branded) temp gun has consistently been the farthest off from the Exergen (generally reading between 20 and 40 degrees lower). The TG1 from tempgun.com has been the closest (generally within 5 degrees F). I have one of those in my tool box as well, just in case something happens to my Exergen. (Here's a link to it) Break - Stubbs, you coming to PNB this year? I'll be bringing down the same crew (+1 new guy) from DC this year - can't wait... |
If you are going to invest in a temp gun. The exergen is the only one worth buying. I have a Raytek that is OK but I trust the exergen my friend has any day over anything else. I have seen many cheap temp gauges that are way off. You invest a lot of money invested in everything else. Why cheap out on the temp gun? It's the same with your fuel and everything else.
Lol!
Unless said user is sending their IR temp gun off yearly for certification and any necessary re-calibration, the name on it means absolutely jack-squat in terms of accuracy. They all lose accuracy over time.
Heres my take on it, i own the exergen and The Micro TEMP - Both amainhobbies sell(they no longer have the micro temp listed)
but it was about $40.00 USD vs 240ish(prices vary ) I use both for breaking in engines and eletric cars... the micro temp is always within 5F, wish i could return my exergen... |
Thanks for all the feedback guys. I'm for sure not trying to spend almost 300 on a temp gun! I think the 50 dollar range is more or less about it.:lol:
Originally Posted by I<3RC
(Post 13070704)
And with your spare $250, you can treat yourself to another new engine |
Originally Posted by wombat
(Post 13070710)
:nod:
You can also use spit. Its free and always accurate. :sneaky:
Originally Posted by 305M3
(Post 13069675)
I'll 2nd, 3rd, and 4th this statement... There are two things I keep tight dibs on at the track - my radio and my exergen...
Break - Stubbs, you coming to PNB this year? I'll be bringing down the same crew (+1 new guy) from DC this year - can't wait... I had hoped it would be healed up enough that I could go, but I just came out of the sling 2 weeks ago, and I've got several months of physical therapy before it's back to even being "functional". My range of motion is about 50% in most directions, but less than 25% in a few positions. I also can't lift more than 5 lbs with that arm right now either. As much as I hate missing PNB, it just made sense to sit out this year. I'll be at Wicked Weekend in August for sure though! :D |
(Post 13071340)
Unfortunately, no. I had surgery on my shoulder at the end of January....ironically enough, it was to repair an injury I sustained while turn marshalling at PNB last year, when I tripped over that big-ass fire hose that was laying near the RH side of the track.
Originally Posted by Rsickles
(Post 13070221)
One thing that the Exergen does well is compensate for the Emissivity of different objects. IR thermometers analyze the radiated heat to determine the temperature of an object. The better ones can better compensate for different emissivity values, and more accurately read temps from different color surfaces / different materials. Without going into a lot of details, a flat black surface will have a different emmissivity than a gloss blue surface, which will have a different value than a shiny aluminum surface. A good IR thermometer can handle this difference better than the lower cost versions. As I said before, for those that believe in them, nothing but an Exergen will do. For those that don't, they'll likely never be convinced to spend the money for one. Everyone is entitled to their own opinion..... |
Originally Posted by MotoGod
(Post 13071468)
Suck it up Sally! ;-)
(Post 13071196)
I temp mine....just as a nice confirmation of what happened during a long race. I never tune by temps though....just another tool to use while tuning ;-)
(Post 13071340)
I had hoped it would be healed up enough that I could go, but I just came out of the sling 2 weeks ago, and I've got several months of physical therapy before it's back to even being "functional". My range of motion is about 50% in most directions, but less than 25% in a few positions. I also can't lift more than 5 lbs with that arm right now either. As much as I hate missing PNB, it just made sense to sit out this year. I'll be at Wicked Weekend in August for sure though! :D Get well brother... |
(Post 13071559)
Like I mentioned in my post, I do send mine off for calibration periodically. It's never needed adjustment.
One thing that the Exergen does well is compensate for the Emissivity of different objects. IR thermometers analyze the radiated heat to determine the temperature of an object. The better ones can better compensate for different emissivity values, and more accurately read temps from different color surfaces / different materials. Without going into a lot of details, a flat black surface will have a different emmissivity than a gloss blue surface, which will have a different value than a shiny aluminum surface. A good IR thermometer can handle this difference better than the lower cost versions. As I said before, for those that believe in them, nothing but an Exergen will do. For those that don't, they'll likely never be convinced to spend the money for one. Everyone is entitled to their own opinion..... Its said you shouldn't tune a nitro engine by temp anyway so really, a reading within 5-10° should be enough to give a good idea on how things are going shouldn't it.? |
Originally Posted by ozziii
(Post 13072437)
I only have the little blue Duratrax Flashpoint but it has a setting to change the emmissivity value to suit the surface your pointing it at, I'm not sure how much of a difference there would be by changing it but I might test it out when I can.
Its said you shouldn't tune a nitro engine by temp anyway so really, a reading within 5-10° should be enough to give a good idea on how things are going shouldn't it.? You're right though....my older O'Donnell was 30 degrees low. So I would just add 30 to what it read and go on with my day. lol Now I too have an exergen. MUCH MUCH better temp gun. |
I used to think my Raytek was accurate but someone shot my stuff with a bluepoint (snap on) and it's 40 degrees different. but his gun looked like it was thrown around in a garage for 6-10 years already. full of grease and oil etc. and I've tested mine against a contact type pyrometer and it reads the same as it but that was about 8 years ago.
but I would love to find someone with a exergen and see who's is closer. the exergen while so over inflated priced is the only ir gun in the world certified accurate by nist . |
(Post 13070710)
:nod:
well put
(Post 13073910)
Exactly! hahaha
http://www.ebay.com/itm/NON-CONTACT-...item232a230aaa |
(Post 13072503)
In theory yes, but the more accurate data you have to use....the better the results are going to be. So if you buy a cheap temp gun, then figure out how far off it is and adjust it's readings when you use it.
You're right though....my older O'Donnell was 30 degrees low. So I would just add 30 to what it read and go on with my day. lol Now I too have an exergen. MUCH MUCH better temp gun. There are definitely deals to be found. |
(Post 13075097)
......that he got from me, for WAY less than $270. :D
| All times are GMT -7. It is currently 12:49 AM. |
