m2c toe block system?? >
Old 02-16-2014 | 10:15 PM
1evo RRR Driver's Avatar
Default m2c toe block system??
Who's running the M2c rear toe block system on the d812?? I'm confused, i bought it but I'm not sure if i should use it!! The stock rear toe block on the d812 has adjustment pills up n down, the m2c appears only to adjust toe in the D block! Is everything on the D block of the m2c system only on centerline? And all antisquat is adjusted in the C block? Please help
1evo RRR Driver is offline
Old 02-17-2014 | 05:53 AM
M2C said to me he did not intend to support the D812 in the future, so as a result I'm boycotting his brand. Customer can't buy what he won't make!
Eivind E is offline
Old 02-17-2014 | 10:12 AM
jmaxey51's Avatar
did you buy the full kit or basic kit? the basic kit doesn't come with the offset pills (i believe), you can get the other pills and use them to get 1/2-1 degree anti squat in the D block. Contact Mitch and he will help you and give you all info you will ever need, super nice guy. all his contact info (even his phone number) is on his website: m2cracing.com
I have the MBX7 and MBX6 full kits and has everything for D-block anti squat.
jmaxey51 is offline
