Like Tree150Likes
Xray XB8
Old 04-01-2014, 11:56 AM
  #841
Trader Rating: 32 (100%+)
Originally Posted by jbranham50
I will be at HARC next weekend @ Mike's.
Thanks, Ill be there, prob wont race since i dont have the new car yet, but will be there to spectate. Gonna reach out to Jeremy to order me one this week.
Also found this.
http://www.thercshack.com/xra355061f...ter-long2.aspx
Text straight from the site.
Item Number: XRA355061
Manufacturer: Xray
Manufacturer Part No: 355061
Add to a new shopping list
Email this page to a friend
Diff outdrive adapters for front/rear differential made of HUDY Spring Steel™. Special enlongated design secures the drive shafts so they do not fall out in heavy jumps when using the new longer arms. Strongly recommended for use in front when using the new long arms. Set of 2.
mcion is offline
Old 04-01-2014, 12:49 PM
  #842
Frank L's Avatar
Trader Rating: 148 (100%+)
Those are xt9 out drives. They should solve the problem. If you are using 13x16 shims to shim the diff they have to be cut as they will not fit over the outdrive.
Frank L is offline
Old 04-01-2014, 12:51 PM
  #843
the heat mizzr's Avatar
Just finished our XB8 we are taking it out to the season opener at LCRC in Oakland Mills, PA to test her out for the first time!
https://www.facebook.com/johnny.lai.148#
the heat mizzr is offline
Old 04-01-2014, 02:02 PM
  #844
TIX
TIX's Avatar
Trader Rating: 17 (100%+)
the truggy outdrives are perfect
Here's a pic of them on the buggy without the shock with the compression as far as the car will allow. Its about 15mm more up travel than when the shock is mounted. I also have 1 pills in and the 1mm spacers removed in this picture. Its as deep as I can get the shaft to sit into the outdrive.
They only just start to touch the inside of the outdrive at this point. When the shock is mounted there is plenty of clearance. There will also be more clearance when I go back to 0 pills and put the spacer back.
Its a lot hotter here than it is in North America and Europe. The arm plastics are just flexing that bit more allowing the shaft to pop out
TIX is offline
Old 04-01-2014, 05:04 PM
  #845
ykc
Attachment 1183238
Thanks a lot.. Look like I need order some of those..
ykc is offline
Old 04-01-2014, 05:55 PM
  #846
TIX
TIX's Avatar
just be aware that if you use the long outdrives, you have to snip the shims so you can spread them apart to fit over the bell on the end when shimming the diff
TIX is offline
Old 04-01-2014, 06:04 PM
  #847
ykc
Thanks will do just that.
ykc is offline
Old 04-01-2014, 06:07 PM
  #848
TV
Just my opinion, but I'm not sure changing outdrives is necessary. If you run the suspension bushings inside and down, where most of the team runs them, the dogbones are deep enough in the cup so that they don't pop out.
TV is offline
Old 04-01-2014, 06:32 PM
  #849
shesha's Avatar
Just finished building my second xb8, the new batch obviously, as the front diff case and back are all in one bag, as well as the front pillow ball different machining. So there is no difference between front and rear diff cases, case closed.
Still have to come across the universal shaft popping out issue, none so far, and running stock settings, by any chance the ones who popped out, are your upper arm bushings inwards, center or out am guessing most likely some have them center.
shesha is offline
Old 04-01-2014, 06:35 PM
  #850
ykc
Mine are inwards, same as my friends which also have the same problem.
ykc is offline
Old 04-01-2014, 06:39 PM
  #851
fullout's Avatar
Why is the team running the front suspension blocks down and in? To minimize bones falling out or for handling purposes?
fullout is offline
Old 04-01-2014, 06:42 PM
  #852
TIX
TIX's Avatar
That's more of a temporary fix. Not everyone wants to run that position on the pills.
I have mine in on the FF and in and down on the FR for more kick up on the rough track. I haven't dropped a drive shaft but know people who have. I have heaps of truggy outdrives so ill just play it safe
TIX is offline
Old 04-01-2014, 07:18 PM
  #853
Z-Man.'s Avatar
I will too Marcus, im not gonna race mine but ill have it with me.
Z-Man. is offline
Old 04-01-2014, 08:22 PM
  #854
TV
Just gives the car a little more steering; narrower and a lower roll center.
TV is offline
Old 04-01-2014, 08:54 PM
  #855
Trader Rating: 7 (89%+)
I measured it a while ago. I'm pretty sure the 1 pills are around 1.4mm of movement. The .5 pills are about .7mm. So your right a 1mm offset hex would be alright.
I meant to say remove the 1mm spacer and move the pills to get 2mm and use a 2mm hex.
Different upper link locations will also affect the driveshaft plunge.
So If I will be using my plus 2mm hex I have to move my pill inwards and removed the silver shim? I am sure it has some effects on the handling but maybe I wont even feel it.
oggietiu is offline
