Kyosho Burns Engine Replacement >
Old 12-03-2013 | 05:13 AM
Default Kyosho Burns Engine Replacement
I really need some help. I am trying to replace an old OS Max 21 RF in my restoration project Kyosho Burns.
The problem I have is the old engine has a collet on the shaft to which a keyed spacer fits followed by the flywheel, then a 2 shoe clutch.
Newer engines have no collet on the shaft so I cannot use my current spacer /flywheel.
Has anyone any ideas or have you done this before. I have attached a picture of the current setup.
Any help would be appreciated
Biodad25 is offline
Old 12-03-2013 | 10:23 AM
indeed you can't use your spacer/flywheel.
but you can use a cone + modern flywheel. I used a flywheel from the next generation Infernos on my Turbo Burns. Actually, any flywheel that has a similar diameter, and similar distance betw engine front & wheel should fit, just check at your local store. And get the shoes & springs that go with it.
(note : some Burns had plastic bevel gear on the diff. I'd avoid investing in such a car... Only the metal-to-metal bevels have enough durability to justify further investment)
Phred2069 is offline
