JQ Products "White Edition"
#47
Hey there sykemike the universals hold up extremely well very strong in my opinion this will be the perfect Buggy for a newbie not as aggressive as the Yellow and first version all round it's going to be a easy car to drive hope that helps you abit
#48
they hold up a long long time, say at least 6 gallons, unless a factory issue would happen
#49
Thanks for the reply. I'm assumeing the reciever battery goes up front. Will my serpent reciever batteries fit the jq? Part# ptk-lp-rx2600-s-2s from amain. I use all high voltage equipment.
Last edited by sykemike; 10-28-2013 at 07:34 AM. Reason: the place i got the battery
#54
You can run most style hump packs in the front box or rear box with the 2013 Radio Tray. Its all about weight distribution. I personally run a 1600 mah hump pack myself in the front box and have it wrapped in foam and still had room. I also ran this battery on the old tray, I just had to space the front box lid with a couple washers to get the clearance I needed and ran the receiver in the rear box.
#58
JQ did a good job with the white edition. Just don't tell him I said so.
#59
