Tekno NT48 Thread
#1276
http://www.amain.com/rc-cars/xray-ce...55012/p227253t
hanks but theres only one left. Do you think that wouls also fit?
#1278
Tekno has the new spurs on their website. Part #5119. Fits both NT and NB48.3.
#1280
13 tooth clutch bell
48 tooth spur gear
9 tooth pinion
40 tooth diff ring gear, thus gear ratio was:
48/13*40/9 = 16.41 gear ratio
The new gear ratio with the 46t spur is:
46 tooth spur gear
9 tooth pinion
40 tooth diff ring gear, ratio is:
46/13*40/9 = 15.73 gear ratio
What does this mean? Take engine rpm, divide by gear ratio and that is the rpm of your tires.
Therefore the 46 tooth spur will theoretically have more top end by about 4% and reduced bottom end torque.
Hope this helps..............
#1281
Gearing
Thanks Retired09. Yeah, the top end gain I like. Loosing that bottom end torque, idk. Idk how noticeable that will be. I don't want the truck to seem sluggish coming out of the corners. Theorectically, using a 44T spur shouldn't be as dramatic as using a 14T pinion so I'm going to try the 44T and see what I think. Hopefully it gets here fri so I can try it on sat.
#1282
Please be aware that the new spur gear (all NT spur gears) is meant to be used with the new chassis (TKR5407). When the two are used together there shouldn't be any more spur gear issues. Thanks.
#1284
The NT48.3 1/8th Competition Nitro Truggy Kit is now Available!
I am sure you have seen the news, but I thought I should also post here. The new NT48.3 is here and now available! A few pics:
http://www.teknorc.com/shop/tkr5406-...ro-truggy-kit/
Maybe it is now time for a new thread?
#1285
The TKR5415B is still the option. It is modified slightly (thicker), but we kept the same part #. They were out of stock for so long that pretty much any shop that has them now will have the latest stock. They are available now on our site as well.
#1286
I have a custom painted Proline Enforcer body for Sale if any one is interested, its also in Australian dollars if anyone abroad is looking, cheers, painted up 2 Tekno ones, so this one is sitting idle
http://www.rctech.net/forum/australi...nted-body.html
#1288
Just wanted to share in case anyone hasn't seen the new aluminum throttle horn Mitchell at M2C Racing made for us nitro Tekno owners.
Attachment 1317956
Attachment 1317957
Attachment 1317956
Attachment 1317957
Yup, very nice piece. Definitely picking a few up..
#1290
I had the same thing happen it was the return spring making the ball end pop out so if you. Have a return spring on you truggy check that if not just put a different one on
