Tekno NT48 Thread
#61
#62
I just order a NT-48, I see no setup for this truck on Tekno web site, everybody running box setup? I have a first batch ET-48 with bad shim ( never run it and replace with good ones) the NT-48 doesn't have the bad shims, does it? I have 3 new Fioroni adjustable clutch that I was running in my Eight-T 2.0 with Ofna style clutch bell, just hope It will clear the tank.
#63
If the clutches are the same length as the Losi clutch it should work.
The box setup is the best place to start. We will be developing and posting new setups soon. Thanks.
#65
The old (good) shims are included in the kit. The incorrect shims are also in the kit, just don't use those.
#69
These are the right shims you need for the diff.http://www.teknorc.com/shop/tkr5145-...x17x-3mm-6pcs/ use these.
#70
The correct shims are included with NT48. You'll see them when you open the package.
#74
Also I mounted a FTW truggy body for MBX6t and it "fit" you might have to cut out the area for the front shocks and drill different holes for the towers but if you don't like the tekno body thats an option with modifications. I ran my nt48 last weekend and it ran great, cant wait to get back out to the track tomorrow, I'll try to get someone to record while I'm driving
I would say the biggest con is not having a split center diff, and the brake linkage isn't as easy to adjust as others.
Some pros would be high quality plastic and an awesome servo / rx tray.
13Likes
