TLR 8ight-T 3.0!!!
#1456
I was just liking the way the box was modded to where you don't have to remove the throttle linkage for easier access. But I don't think I will be doing it. Just innovative...
#1457
Im running the same pack. I pull it out after every race, install it when I get to the track in the morning. Its a great pack that's lasts me about 80-90 minutes of use...
#1459
#1461
I haven't seemed to have much trouble with the cover either but I'm all about making things the way you want them. I picked up a Hitec 5955 for the steering. Has anyone had much experience with the protek servos. I've been considering some for a different application. On paper they seem awesome and the price seems right I just haven't seen any at the track.
#1462
#1465
Hi, I'm not getting full left steering. Endpoints adjusted, turnbuckles adjusted, toe set.. Almost as if the steering post without the servo saver is rotated out of sync.
If I adjust the turnbuckle to compensate, it throws the toe out.
Any help appreciated, see pics.
Steering Centered
Steering Left
Steering Right
Steering Centered
Steering Left
Steering Right
#1466
try a different servo, see what happens
#1468
Thanks for the feedback.
I have a Hitec 7995 333 oz.
The servo saver was loose, I will put it back together & clean it, then post a vid to get opinions.
Thanks a ton eh...
Thanks a ton eh...
#1469
Anyone know where I can get a brass flywheel collet for the Losi 8ight 3.0, 4 shoe clutch? Can't buy them separately, have to buy set, and it is way too expensive, or an alternative collet that works?
#1470
Team Losi Flywheel Collet W/Shims:Nt-Ad2 [LOSA9376] | RC Cars & Trucks - NitroHouse.com
