Like Tree12Likes
Tekno NB48
Old 05-30-2014 | 08:24 PM
  #1471
Matthew_Armeni's Avatar
Originally Posted by Casketman
So I dont know about others but Ive had an issue with some of the stock screws. Mainly the 3x40 screws used for the hinge pin blocks on the bulkheads.
Even with a band new VP Pro 2.0 bit,it still skips out and is right on the edge of being stripped. As if the hex bit hole isn't deep enough for the bit to sit down in like other screws.
So I decided to change those out and do something different before I do strip the screw head.
I went to Amainhobbies.com and picked up some Protek 3x40 cap screws and some Lynx Heli countersunk washers.
The end result doesn't look bad or as if it wasn't stock(in my opinion). But mainly,no more chances of stripping a screw.
Great mod, I'll add that to page 1.
Matthew_Armeni is offline
Old 05-30-2014 | 08:30 PM
  #1472
That's a good mod and I applaud your effort.... however completely unnecessary. Sorry.
I have personally found between all the Tekno vehicles I run, 1) the wing screws and 2) the rear bulk screws are most prone to bending. That being said, I have never stripped a single one after multiple seaons.
Recommendations: Use chapstick or oil to thread it for the first time. Use a QUALITY driver (I've heard "questionable" feedback on the VPPro brand to say the least) and you're much less likely to have issues. Use a electric driver to initial threading which decreases the likelihood of stripping probably 5-10 fold. Just ensure that if you do that you go SLOW and keep it cool and lubricated in order to not stress the plastic/composite.
While I'm not a losi man for vehicles, I use them as a %#@%#&%(@@&$@ hammer and they still go strong I replaced my first 2.0mm losi last season bit after roughly 10 years of use finally... I think that speaks for itself.
RokleM is offline
Old 05-30-2014 | 08:36 PM
  #1473
Casketman's Avatar
The bit I have fits to good but I also have Ofna bits and the same happens. I also use a mini driver because there is no way in hell I'm screwing those long things in! lol.
The bits just pop out because they don't sit down far. It's much like the problem people will have when screws have to much paint on them and the bit doesn't fit well because of it. These don't have paint so that isn't the issue but it feels like it.
Casketman is offline
Old 05-30-2014 | 08:48 PM
  #1474
Casketman's Avatar
Thanks for the front page pasting!
I have not tried this change on the front but will soon.
Old 05-30-2014 | 09:54 PM
  #1475
I just like not changing bits on my driver for those 2 screws
Old 05-30-2014 | 10:04 PM
  #1476
Casketman's Avatar
I didn't even notice that lol. Good point!
Old 05-31-2014 | 08:26 AM
  #1477
That's a great tip. I also find that the 3x40 heads are soft and prone to stripping very easy. Don't have any issues with the other sizes. Just that one for some reason.
mr240 is offline
Old 06-01-2014 | 05:18 PM
  #1478
Graham11's Avatar
Originally Posted by BigInJapan
Yeah I've bent a steel one before. Was not expecting it. Wasn't off a jump, it traction rolled and then cartwheeled a few times. It was at high speed. In my opinion, the chassis on the nb48 is very flexi, it is milled out to within an inch of its life. don't get me wrong, I like the fact that it's lightweight, but I do wish that the rear and center braces overlapped. At the moment there is a small gap between the two (looking side on) where there is no bracing, and that is exactly where my chassis bent.
Since then I have put many more laps on it, and had many more spills without it happening again, so it's just one of those things. It handled some tough practice laps last weekend really well, to the point where I think durability is a non issue, besides some random breaks.
Hey Japan,
The link from your throttle servo to the LSN side of carb should be perpendicular to the chassis not on an angle like that, your going to mess up your carb. Loosen the set screw on the ring w the ball end on the carb and rotate it so your link is perpendicular
Graham11 is offline
Old 06-01-2014 | 05:58 PM
  #1479
I am pretty sure that the beveled head of the 3x40 screw needs to "Lock in" to the rear hinge pin holder to keep it from moving.
masher81 is offline
Old 06-02-2014 | 12:32 AM
  #1480
vandalzzz's Avatar
Originally Posted by vandalzzz
Also i was thinking about my fast clutchshoes wear issue for last week, and realised that it happened because i've lost on of the four screws holding motor stands (closest to the center of the chassis), and such rapid wear is a result of increased vibrations due to lost screw (actually noticed that fact only after ride). Because everything else was fine: tune a bit rich, surface very slippery, no stones in drivetrain.
So, can anyone confirm/decline my thoughts about clutchshoes' rapid wear came after running engine mounts with only 3 screws fastening them to the chassis?
vandalzzz is offline
Old 06-02-2014 | 02:25 AM
  #1481
DBL15's Avatar
Should not effect it at all mate.
When you say rapid wear how long are you talking ?
What springs are you as that might make a difference as well
DBL15 is offline
Old 06-02-2014 | 03:37 AM
  #1482
vandalzzz's Avatar
Rapid is goin from 'worn a bit' to 'worn down to spring ends' in a 0.5L.
Springs are stock.
Old 06-02-2014 | 04:59 AM
  #1483
DBL15's Avatar
Springs are stock.
Ok that's really weird mate I am easy getting 3 to 5L on them no probs something is not right in there that's for sure.
DBL15 is offline
Old 06-02-2014 | 05:24 AM
  #1484
Engine torque, buggy weight and how much you pull the trigger determines clutch wear. Heavier springs wear shoes quicker, I am on a gallon on the kit shoes and they still look good. I would be intrested to see pics of your clutch.
underway is offline
Old 06-02-2014 | 09:37 AM
  #1485
Yes, that's true. The counter sunk screw was chosen to center or "lock in" the holder. The holder is also keyed to the chassis so that helps if you use the caphead screws, but you're right, it won't be as accurate as the CS screws.
