Tekno NB48
#1294
#1295
Alright Tekno, one thing I would like to see added to the option list of this car is carbon clutch shoes. Carbon shoes really smooth out the clutch action and can make the aluminum shoes last longer. I noticed when I raced minne is that the clutch is very grabby, enough so that I think its out of the tunable range of the clutch springs.
#1298
I love this buggy
Kit arrived wed, threw it together and got it broken in just in time for the races today.
Dual wielding buggies yields you +5 attack and speed (there's a gamer/RPG joke for those of you that get it).
It performed very well, I made it through my first 30 minute a-main (which is a feat in itself given the fact I haven't done nitro in a long time and we have a lot of really good local drivers), and pulled of a 7th place finish. Officially broken in:
It could indeed be partially tires, but I do need to work on the steering. I have less than some and my e-buggy is quite a bit more aggressive (to the point of being out of control I think in comparison to the NB48). That being said, I think I had 5-10 minor mistakes in the a-main, so my NB48 was the more consistent of the two today.
I'll break it down and play with the setup this week.
#1301
but this car has a ton of rear traction even in the front motor config.
#1303
Been noticing the same thing on my setup. I'm loving how planted it is but pushes mid turn, on high bite and low bite. Me and Mike Asher have been discussing it and we are thinking a solid solution would be the 10 degree spindles. That's my first change I will make as well as dialing out a lil front brake. After that we will see but I'm thinking a lil softer sway bar to get it to dump a lil more. But my gut feeling is the 10 degree spindle change will be what we are looking for as it was exactly the the same on high bite and loose conditions back to back days. I've been testing some piston oil combos as well and I'm liking teknos 8x1.4 fr with 600cst and 8x1.3 rr 525 cst. A lil more testing before I get a good solid setup, but definitely heading the right direction as of now
#1305
R/C Tech Elite Member
Yes; I've been thinking about a .21 short course because of all the common platforms between the two.
Seems to click. The SCT410 was born from the EB48, using a lot of the same parts.
Why couldn't a nitro SCT410 be born from the NB48?
I wish I had an NB48 so I could sit down and figure out how to get the SCT410 to work in nitro. I'm thinking just take an NB48 and put the front and rear SCT410 front and rear complete diff/tower/bumper assemblies on?....
I've been wanting to see a bump start SC truck!
Then the name could be the NSCT410. And we can sound out the acronym as the Nasty 410
12Likes
I didn't have enough to do the double wrap around the tank. Picking up some more tube, a fuel filter, and a power switch (didn't realize it wasn't included) at lunch.
