Mugen MBX7
#4246
HOT BODIES.
KT ran them too not sure who else. Not many people talk about it.
http://www.rctech.net/forum/nitro-of...l#post10466237
Do you mean i can use everything in this set even the orings(http://www.amainhobbies.com/product_...aintenance-Set )? So the shock body and shaft of the x7 is the same diameter from that of HB?
#4247
Hi Motorman007,
#4248
Hi Motorman007,
Nope just the bladders :/ kinda sucks but they are way better then stock bladders.
use the Losi low friction/ JQ spacer trick for less shaft friction.
KT
#4249
#4250
Thanks so much for the heads up KT, may i know more about the 'trick'? Any link that i can read on will be nice too, hehe.
#4251
Change your stock orings/spacer to
https://www.amainhobbies.com/advance...74%09&x=0&y=12
https://www.amainhobbies.com/advance...-B-037&x=6&y=5
you will need 2 of the JQ packs as you need 4 of the 1.5mm plastic spacers
#4253
Thanks a ton for the links man, added them in my cart already, will order everything pretty soon, cheers....
#4254
#4255
#4256
What set up are you guys using? Going from set up from the box?
Also are you guys running 7 7 3 in your diffs like the stock set up states?
#4257
#4259
go to page 22
http://www.mugenseiki.co.jp/mugen/do...nual_e2001.pdf
These ORINGS are thinner i believe.
Team Losi Racing Low Friction Shock Shaft O-Rings (8)
[TLR5074]
so you need the JQ
Spacer to make up the different in space
JQ Products Shock Bushing Set (4) [JQP-B-037]
and at the end of the shocks you used the stock mugen plastic
E0545A
SO IT SHOULD LOOK LIKE THIS
LOSI ORING Low Friction Shock Shaft O-Rings
then JQ SPACER small guide bushings
then LOSI ORING Low Friction Shock Shaft O-Rings
then Mugen Plastic E0545A
Let me know if that is clear enough
[TLR5074]
so you need the JQ
E0545A
#4260
Setup
So I have been looking at a TON of setup sheets and for the rear arm spacer, the setup sheet is pointing to the FRONT on the rear arm, so are you guys running the 1mm in the front or rear of the rear arm??
ALSO....I have lost TWO shock bushings where the ackerman screws in The first time I had no loctite but the 2nd I did....anyone else loosing these?? And at like $7 for 2 of them thats crazy
