Official VP-Pro USA Thread
#316
Yep ok thanks for that, I will have to get some of the newer versions then, using the belted Gripz & Blades last weekend, I had very little traction where any loose or dusty surface was, even when hard underneath & only really had traction on the clean hard packed areas although my suspension was a bit firm as well so that wouldn't of helped.
Looks like a better start re-stocking.
Also, what compounds do you recommend, should I go with superflex supersoft & ultraflex soft or get medium flex medium/soft as well.
#319
Yep ok thanks, I will have to see who else has stocks of the latest designs over hear & try out the soft tires first although we are in the cooler months here at the moment so super soft might be good, might help my driving to.
#321
#326
No need for super flex this time of year I would use ultra flex or even try the medium flex in the summer heat.
#327
#328
