Serpent 811 Cobra Buggy 2.1
#2296
U need to change that as well since the carbon plate u mentioned b4 used to extend it so the installation of new link is require
#2297
The set comes with new links because the stock ones are too long for the new Ackerman design. Serpent wouldn't supply them if you didn't need to use them!
#2298
in this case i agree with you but i still had to confirm because many times companies supply supplemental parts in a set that aren't needed.
#2299
arite guys thx for all the help with this new ackerman as i know its not complicated but after i got it installed the steering turnbuckle rides WAY to close to the sway bar mount. Upon suspension compression it actually rubs when steering! I thought I installed the turnbuckles the right orientation as the document on the website shows. Should I flip them around? I used the new tie rods provided too. Any ideas much appreciated
*note: I am using 1 bump steer spacer on both turnbuckles
#2301
wow yea thats really annoying. wats the best or fastest way to cut the metal other than a dremel? i dont have the appropriate dremel bit at the moment.
#2303
cool thats wat i thought about the wire cutters may work but wasnt sure. Ill just get some new dremel bits. this is pretty shitty on serpents part, quite surprised actually
#2304
#2305
What effect does the new Ackerman do or is it just the same as option 3.
Would be nice to have the 3 options on 1 Ackerman like other manufacturers.
The bearings are a nice addition as the old style just seems to work themselves loose and wear really quickly causing slop.
Nice work Billy
Nice work Billy
#2306
Nice work Billy
Nice work Billy
#2307
#2308
#2310
New cobra 2016
Any leaked pic of new buggy?
