-   Nitro Off-Road (https://www.rctech.net/forum/nitro-off-road-130/)
-   -   INTECH RACING - BR-6 BUGGY!!! (https://www.rctech.net/forum/nitro-off-road/651300-intech-racing-br-6-buggy.html)
rcmania74 07-14-2013 06:12 PM
Originally Posted by tony montana (Post 12347903)
yeah if you have inserts wrong then that is def the problem. I knew it had to be something going on. I have not heard of anyone saying that the car is loose for them
What One Do.you Use In The Front Front plate
VPProUSA 07-14-2013 06:43 PM
Originally Posted by rcmania74 (Post 12347517)
How Does .5 Give Me 3 Degrees I assumed you basically put 1.5 on one side of 1.5 on the other side of tO Equal 3
0 insert in the rear toe block gives you 2.5' total toe in. The standard is .5 out which = 3' toe in.
VPProUSA 07-14-2013 06:45 PM
Originally Posted by rcmania74 (Post 12346862)
I Heard This Car Has Good Corner Speed Though
The Intech does have fast corner speed and also truggy gearing so it accelerates very fast and is very light. All that makes it feel looser then a heavy buggy or buggy that does not have much steering like most pillow ball cars lack.
It might take some time to get used to it. Also, after it breaks in, the traction will increase.
rcmania74 07-14-2013 07:22 PM
Its My Fault Its Screwed Up...I Shoulda Looked At The Chart...I Will Fix It And Test It At The Other Track This Week Before Futaba.. I Can Tell Its A Good car
rcmania74 07-14-2013 07:53 PM
Ok So.the book front plate set up actually give u front tow with the recommended inserts
YANMAN 07-14-2013 08:14 PM
Try one of these setups, you will see that they are real close. This will get you in the ball park and you will just have to make small adjustments.
http://www.rctech.net/forum/12180315-post1167.html
Ben I hope you don't mind me reposting your post.
rcmania74 07-15-2013 06:54 AM
So.i Added Anti Squat And Noticed The Rear Arms Hit The Outdrives When I Do This.... Are People Just Dremmeling Some Material Out For Clearance?
VPProUSA 07-15-2013 07:47 AM
Never seen that. Maybe email a picture.
gofast072 07-15-2013 08:26 AM
Hey scott i will be at the futaba race, will be there early friday, please come see me i will get you dialed in, ill post a pic of my car when i get it ready so you'll know what to look for prolly be thursday evening
Ben Burtle 07-15-2013 09:41 AM
Are your arms still forward?
VPProUSA 07-15-2013 10:05 AM
I run my front arms middle and rear arms all the way back.
masher81 07-15-2013 10:27 AM
Have you tried running the arms and hubs forward... what was the result?
VPProUSA 07-15-2013 10:29 AM
I move my hubs forward when the track is loose and on real tight tracks.
masher81 07-15-2013 10:35 AM
OK same here. On just about every 1:8 scale car I have had I have found (for me) that moving the hubs forward makes for a better handling car. (for my driving style)
rcmania74 07-15-2013 02:21 PM
thanks to gene sending me the chart with the right information on the inserts and I put them in the right places I did get to go to a track that is nowhere near as high quality is ours and run it and it is a lot better there's like zero traction I don't care what you do on this track its pretty bad but it gives me an idea how the cars going to be and it's going to be much better now .... thanks
