INTECH RACING - BR-6 BUGGY!!! >
Old 03-17-2014 | 08:37 AM
  #1666
they say the original bladders are no good and to use the bra ones. but i can't get them so the next best thing are mugen ones.
some have said they have used the pistons with success too!
and the o-rings... thought may as well try them too!
picko990 is offline
Old 03-17-2014 | 03:35 PM
  #1667
Stick with the intech pistons, the intech shock bodies are 15.2mm and only intech and vp pro machined 15.2 pistons fit correctly. And I highly recommend the convex bladders, not sure if mugen ones work or not, my guess is they probably will but I would stick with the convex bladders if you can get them, where are you located?
gofast072 is offline
Old 03-17-2014 | 07:19 PM
  #1668
im in indonesia. they have complete stock on the current kit but don't have old stuff. therefore they don't have the br5 bladders. all their drivers use the mugen bladders. so the intech o-rings are ok?
picko990 is offline
Old 03-17-2014 | 07:25 PM
  #1669
Yes
Old 03-19-2014 | 07:14 PM
  #1670
IRSR's Avatar
Post SWISS A-7075 FRONT SUPPORT PLATE
This Swiss A-7075 Aluminum Front Support Plate provides increased strength without extra weight for the INTECH BR-6 series.
IRSR is offline
Old 03-22-2014 | 03:13 AM
  #1671
speedy2's Avatar
Can anyone tell me how much distance there is between the 2 brake caliper screws ?
speedy2 is offline
Old 03-22-2014 | 12:32 PM
  #1672
27.8mm center to center
Old 03-30-2014 | 10:32 PM
  #1673
IRSR's Avatar
Thumbs up FRONT SUSPENSION ARM HOLDER 0'±1.5mm
This optional CNC Aluminum front suspension arm holder allows for 0'±1.5mm additional front kick-up on the INTECH BR-6 series. INTECH logo and angles are laser engraved for quick recognition. Provides more tuning options for better performance in bumpy track conditions.
IRSR is offline
Old 03-31-2014 | 03:03 PM
  #1674
luke71933's Avatar
Hi,
How's the durability of the intech br6 . when I crash with my 808 it will be a big one because it doesn't oftenly occur like 3 times in 10 minutes and I have never broken anything. How does this buggy's durability compare to the Xray, and how is its handling/driving.
Thankyou
luke71933 is offline
Old 03-31-2014 | 03:42 PM
  #1675
Originally Posted by luke71933
Hi,
Thankyou
The intech's durability is top notch. I never worry about a DNF with the br6.
masher81 is offline
Old 03-31-2014 | 03:45 PM
  #1676
VPProUSA's Avatar
In 1.3 years, all I have broke is a plastic servo saver arm. Now I use the alum one.
VPProUSA is offline
Old 04-03-2014 | 12:28 PM
  #1677
Hi
Sorry but have anyone a Setup for an Slippery Track??
Thx Balu
Balu1979 is offline
Old 04-04-2014 | 10:57 AM
  #1678
VPProUSA's Avatar
+ YouTube Video
VPProUSA is offline
Old 04-04-2014 | 12:08 PM
  #1679
VPProUSA's Avatar
+ YouTube Video
VPProUSA is offline
Old 04-04-2014 | 10:46 PM
  #1680
im in process of building the kit. just wondering if anyone has changed out the wood screws they use in the front diff case for the pin mount. seems a bit odd that they would use screws like that? if so, what have you swapped them out for?
so far i have changed a bunch of bolts for longer ones. some didn't screw far enough into nuts and others i did not think had gone into the plastic far enough.
cheers
jason
picko990 is offline
