Xray XB9
Old 12-12-2011, 11:22 AM
  #46
Jammin57's Avatar
Trader Rating: 120 (100%+)
Originally Posted by floripaolo
Saw one of the 4 prototypes yesterday...
-narrower chassis
-new radio tray (long and narrow)
-new shock towers
-steering servo mounted upright.
and probably many more stuff I didn't noticed....
And where did you see this???
Jammin57 is offline
Old 12-12-2011, 11:41 AM
  #47
Racing track in Viggiu, Italy.
floripaolo is offline
Old 12-12-2011, 11:46 AM
  #48
alport78's Avatar
did you noticed any difference on the shocks?
alport78 is offline
Old 12-12-2011, 11:55 AM
  #49
Unfortunately no, I couldn't tell if they changed something on the shocks. But the guy driving it, shure knew what he was doing.....
Old 12-12-2011, 08:32 PM
  #50
I heard it was jet powered and the CVD's were made of goooolld.
skye b. is offline
Old 12-12-2011, 11:10 PM
  #51
Wrong. Powered by "grappa", CVD's are dark chocolate (99%) and the pilot was Santa Claus....
Old 12-13-2011, 01:15 AM
  #52
merdith6's Avatar
Default Well
I think geometry changes will be the most important feature. On my 808 the shocks are fine, just a bit too short compared to the mugen for example. I think the problem is the length of the shocks and their relation to the towers and a arms. For example. even with longer shocks mounted on the buggy the uptravel when the chassis is touching the ground you can't roll the car torsionally very far so when you land at an angle off a jump into a turn it bends the a arm, even with the stock shocks, a slightly stiffer material for the a arms would help that too.
The outer wheel bearings need to be the larger standard size, and the servo saver wears fast causing it to not center properly. I hope they fix that.
The rear chassis brace needs to be move just behind the center diff to keep the chassis from getting bent (Big jumps on my two favorite tracks).
The two rear center diff screws from top that hold the center mount together get stripped fairly easily.
Honestly I think the buggy is a little light, especially when it's windy, and why can't a 3.5mm chassis be used. 4mm is to thick, and 3mm is too thin.
That's all I can think of and that's not too many changes.
I think the xray buggies are awesome, and the timing for a fresh change is perfect this time. Not a big fan of a new buggy every year, but whatever. I still run the 08 model and the little changes didn't make much difference on the track. It is time for some bigger changes, but what a run for the 808. It took a good long run....
I would like to see the xb9 take a good chomp at the US titles especially to get more glances from those with bigger wallets than brains.
merdith6 is offline
Old 12-14-2011, 05:50 AM
  #53
http://rc-area.co.uk/blog/2011/12/14...first-details/
http://www.teamxray.com/teamxray/new...62ad82f95d2782
official news not made up rubbish
fastboy is offline
Old 12-14-2011, 06:11 AM
  #54
ronsand's Avatar
Nice
ronsand is offline
Old 12-14-2011, 07:40 AM
  #55
bcr500's Avatar
Trader Rating: 34 (100%+)
Looks like they might have a new wing comeing out with this buggy.Man I cant wait to see what this buggy looks like under the hood.I think they finaly might have just hit the nail on the head with this one.
bcr500 is offline
Old 12-14-2011, 07:41 AM
  #56
Jammin57's Avatar
The towers look shorter and I don't like the body the 2011 body looks the best
Jammin57 is offline
Old 12-14-2011, 08:18 AM
  #57
Sideshow Bob's Avatar
with you on that one, that is def a new body, and wing...and i think the 808 2011 body is the prettiest one out there
Sideshow Bob is offline
Old 12-14-2011, 08:50 AM
  #58
Two-speed's Avatar
Trader Rating: 24 (100%+)
+1
From the profile it looks like an Assocyosho 8.2 TK1
Two-speed is offline
Old 12-14-2011, 08:58 AM
  #59
pickle311's Avatar
Trader Rating: 31 (100%+)
Sounds like they may have something here. Shocks and chassis flex were the big issues and both are being addressed. I'm getting pretty excited about this car, time to start saving up.
pickle311 is offline
Old 12-14-2011, 09:03 AM
  #60
Jammin57's Avatar
Hope they don't wait till february to debut it like they always do, hope you can buy it by then
Jammin57 is offline
