NEW D8 Atsushi Hara Edition*
#5236
Cain
start with tires and get it right. I beams or Impacts sound like your ticket. My current set up I use. 40wt rear, 35wt front if temps are above 70+(lower shock oil by .5 if more traction is desired or by temp. Full rebound rear, half rebound front.
1.3mm piston front and rear. Rear hub inside hole, camber link out in tower-lower hole. I use this set up for all tracks, car is dialed
#5237
True
The reared will be stuck in the groove with the rear end set up that way. Just stay in the groove. In the loom if it's hard packed and dry it will be loose so tire choice and away bars go a long way in those conditions. I like a car a tad loose but to each his own.
#5238
Anytime you raise the rear link on the tower, it will give traction. Same with raising the hub. Try one at a time till you get what you want.
#5244
Yes and running the car a little stiffer. Try orange springs and see what you think with 3mm swat bar. Try 4k in the rear diff as well.
#5246
#5248
90% of the time I run the blue rear springs...
#5249
At least try the blue rear spring. The yellow is actually a little stiffer than they blue but the blue are longer and I like the feel.
Jesse got me started running the orange back in the indoor season and the car was money. He told me outdoors, drop down a spring on the rear.
Seems good to me. Actually, the best the car has ever been.
