regular vs turbo plug >
Old 08-27-2010, 08:47 PM
Default regular vs turbo plug
Can anyone tell me the difference? and which one would be better for everyday play/occasional race?
catlover3178 is offline
Old 08-27-2010, 08:56 PM
jmaxey51's Avatar
standard plugs are better IMO but i do not run them because i only race and sometimes its a pain to change fast. but for you (with mainly bashing) a standard plug will be better and cheaper. but either one will be fine, in my experience standard plug engines are easier to tune.
jmaxey51 is offline
Old 08-27-2010, 09:04 PM
tc5 man's Avatar
i dont have, expreience with turbo plugs or tuneing with them plugs ive always used, standard plugs for racing and i know a lot of people at my track still use them too . i guess it is easyier to tune with a standard plug im not sure.
tc5 man is offline
Old 08-27-2010, 09:07 PM
mike881's Avatar
I'd like to know more about this topic too.
And can somebody explain why everybody says a pretty important addition to the Losi RTR's is a turbo head button?
mike881 is offline
Old 08-27-2010, 09:08 PM
jwm2's Avatar
Theres no real difference in tuning. Turbo plugs cost about the same and sometimes cheaper than the non-turbo version. For an os plug you are going to spend 5.99-7.99 no matter which one you get. I run o'donnell turbo plugs which run about 4.99/ea. The tuning window might be slightly smaller, but if so i can't tell. I hear the turbo heads give the engine abit more hp, but thats just going by what others have said in the past.
jwm2 is offline
Old 08-27-2010, 09:23 PM
jmaxey51's Avatar
for more bottom, ive ran them both ways, it give it just a hair more bottom and more run time.
you can get an OD SS 21 and it comes with both button heads and you can swap back and forth and see the difference. there isnt much difference at all.
jmaxey51 is offline
Old 08-27-2010, 09:54 PM
Trader Rating: 35 (100%+)
Turbo plugs run a little cooler, get a little more runtime, but are a little harder to tune.
Hobbs263 is offline
Old 08-28-2010, 12:53 AM
Roelof's Avatar
I think there are no differences. On paper they have only a different mounting with which the turbo has a better sealing and fits better in line with the combustion chamber. I think the differences people notice is more about different plugwires and mayby after a change the difference in the volume of the combustion chamber (compression)
With normal plugs you have much more choise of brands and types and with turbo you do not have the copper ring which you can always drop and loose.....
Roelof is offline
Old 08-28-2010, 05:05 AM
Trader Rating: 24 (100%+)
What kind of turbo plugs do you use? I know all O.S plugs are HOT i.e the P3. The P4 is super hot.
O/P, heres a quick read of the differences.
http://www.osengines.com/accys/choosing-glowplugs.html
got_nitro is offline
Old 08-28-2010, 06:19 AM
+1 Turbo has a better seal they also last longer but with any motor / plug, only if tuned properly.
riverviewrc is offline
Old 08-28-2010, 06:20 AM
Turbo: A little bit harder to tune (on some engines), longer runtimes and lower temperatures.
Before the Ninja, I ran a RB WS7 L2G, that came with turbo-plug. I "modded" it for standard plugs, and it was noticeable easier to tune. But it did get hotter and the runtime did suffer.
Nilks is offline
Old 08-28-2010, 06:24 AM
mudboger07's Avatar
P3 is a hott plug the P4 is a cooler plug than the P3.
mudboger07 is offline
Old 08-28-2010, 06:40 AM
Yes, I understand.
The P3 is ultra hot.
P4 is super hot.
P5 very hot.
Old 08-28-2010, 07:27 AM
Maximo's Avatar
turbo plugs are not harder to tune LOL ! turbo plugs have more tuning options, but are no harder to tune providing you are running the correct plug........
Maximo is offline
Old 08-28-2010, 07:29 AM
Yes, I understand.
P4 is super hot.
P5 very hot.
no you have it backwards
blackbeardrollo is offline
