Engine Temp
Old 08-14-2010 | 03:13 PM
  #31
NitroXray80809's Avatar
Originally Posted by Shadowhope
well i have a race today guys so im just gonna wing it and hope for the best with my engine
yeah honestly if you got a tune u like and u got a good amount of smoke coming out then dont worry about temp just take off the on board temp for the radio its no good.
NitroXray80809 is offline
Old 08-14-2010 | 08:13 PM
  #32
Shadowhope's Avatar
Yeah well i got to the race early enough to practice a lilbit until it got rained out . After about a tank of gas i was runnin round 290-300 it didnt seem like it was hurtin nothin but it ran very well during practice.... just wish i coulda got to race
Shadowhope is offline
Old 08-14-2010 | 08:23 PM
  #33
jmaxey51's Avatar
replace fuel lines, and exhaust gaskets. that engine shouldnt be that hot. sound like you have some sort of small air leak running that hot. i had an engine that normally runs around 220 run at 260 one day and it was as simple as a bad exhaust gasket.
jmaxey51 is offline
Old 08-14-2010 | 09:47 PM
  #34
Shadowhope's Avatar
well someone at the track today said every engine runs differently so i am ok with running around 290 as long as it says around that area.....
Old 08-15-2010 | 05:46 AM
  #35
Also try to use someone else's temp gun every now and then. They change around alot from day to day unless it's a lab grade unit.
The Working Man is offline
Old 08-15-2010 | 06:40 AM
  #36
Shadowhope's Avatar
I use the Losi Temp Tuner
Old 08-20-2010 | 09:44 AM
  #37
MotoGod's Avatar
You can always test your temp gun on a pot of boiling water. Water boils at 212F ;-) So if your temp gun is right around there...you should be good. It's good to clean the lens on the temp gun now and again though. I had crud on mine and it was reading 20-30 degrees off one race weekend. Freaked me out real fast....
MotoGod is offline
Old 08-20-2010 | 09:46 AM
  #38
KWT-NITRO's Avatar
+1
KWT-NITRO is offline
Old 08-20-2010 | 10:05 AM
  #39
mudboger07's Avatar
You'll need to retune just a tad when we r4ace on the 28th due to how the weather has been, the 350 runs good at around 240-250 at our track, and since your only on about a gallon of fuel id keep it a little rich...
mudboger07 is offline
Old 08-20-2010 | 03:15 PM
  #40
Shadowhope's Avatar
could someone there help me tune it?
Old 04-29-2014 | 01:25 PM
  #41
TheBlueKnight's Avatar
Sorry for the necro bump, did some searching but didn't find much. What spot on the motor do you guys check the temps at? When I point the temp guns laser right on the glow plug/glow plug area my 3.3 Traxxas motor in my new Revo is usually around 220f, but if I point the laser at the outside of the head/motor fins toward the very top it reads at around 270F. My Traxxas manual says to get the reading "at the glow plug", but I just wanted to make sure that's what everybody else is doing to when they talk about their temps on their engines.
TheBlueKnight is offline
Old 04-29-2014 | 02:03 PM
  #42
Glow Plug
Chris Reilly is offline
Old 04-29-2014 | 04:11 PM
  #43
Nitro Tiger's Avatar
And make sure your at a consistent height off the glow plug, different height will
Give a different reading, I normally rest the gun against the top of the head to get same height reading every time
Nitro Tiger is offline
Old 04-29-2014 | 04:13 PM
  #44
Very cool, thanks guys. Yeah, at first I was going off the temps at the top of the head and was like, "geez, my engine sure is running kinda hot at 270-290F. Then I got the temp at the glow plug at only 220-240F and was like, "oh, it seems fine then".
Old 04-29-2014 | 05:07 PM
  #45
Frank L's Avatar
Temp is just a guide. It was said on the 1st page find someone who can help you tune and then you will know how it's suppose to sound. Tune for smoke and performance. That means that it should idle well and spool up nice and then back down. Tuning a nitro engine can be difficult if you don't know what you are doing but watch an experienced tuner dial it in and learn. IMO 220-280 is acceptable as long as it sounds good and has a little bit of smoke. I have ran engines warmer than that and I knew the consequences but never colder than 220, it's just as hard on an engine being too cold as too warm. Different fuels will smoke differently too depending on the oil package
Frank L is offline
