BCE racing custom chassis thread
#1171
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
Bill, got the eco chassis over the weekend, not sure what day it got here thurs-sat because i was in alabama racing nitro with the X3 chassis, this chassis is awesome, will be posting setup later this week when i have time to make a neat/easy to read one.
BTW got my eco chassis in 9 days from ordering it...
#1172
![Thumbs up](https://www.rctech.net/forum/images/icons/icon14.gif)
![Nodding](https://www.rctech.net/forum/classic_images/smilies/nod.gif)
We have been full steam Ahead for the new 012 season
![Rotating Tire](https://www.rctech.net/forum/classic_images/smilies/tire.gif)
We are also working on getting lots of new set ups posted
as I mentioned previous.
Big congrats out to our Hot Bodies Guys Ryan And Smiley
Smiley Got a podium and TQ/ Win with our 4x4 SCTE Pro.
![](http://i20.photobucket.com/albums/b222/rnucell/HBWinsRCProTSSRd1.jpg)
![](http://i20.photobucket.com/albums/b222/rnucell/BCESCTEpreview2a.jpg)
![](http://i20.photobucket.com/albums/b222/rnucell/hbxv2.jpg)
#1173
Smiley Got a podium and TQ/ Win with our 4x4 SCTE Pro. Neo Buggy
Brian "Smiley" Henn reports - RC Pro Texas State Series Round 1 was hosted by Mikes Hobby Shop / Gulf Coast Raceway in Porter, Tx. This one day race had nearly 220 Entries. With 18 heats per round, 3 Rounds of Quals, Followed by the Mains. All Electric Classed had Tripple A's as well. Team Hot Bodies/HPI Racing Driver Brian "Smiley" Henn TQ'ed and Won 4wd SC, Won Expert E-Buggy and took 3rd in Expert Nitro Buggy. My cars were great all day, Ran my base set-ups with no changes. I ran Pink HB Megabites in all 3 classes.
#1175
good job smiley.
HB/BCE FTW![Smilie](https://www.rctech.net/forum/classic_images/smilies/smile.gif)
on a side note all this smack talk about BCE is getting out of hand!!! if you do not want/like his product and are not willing to wait for a great chassis then leave....
HB/BCE FTW
#1176
Thanks Bill and Ryan. Chassis are awesom Bill! The SCTE Chassis is much better than the TLR Tuned. I have a few locals that should be ordering one soon
! A few of the locals that run the D8 really like the way my car feels with the BCE Chassis as well. Here are my setups:
SCTE Setup:
Front:
30wt, #3 Piston, Green Spring, Out on Tower and Arm for Shock Positions, Lower Camber Link Hole on Tower, Full Droop (Unscrew Shock Ends 2 Turns), 27mm RH, 7K Diff, Stock Sway Bar, -1 Camber.
Center:
7K
Rear:
27.5wt, #4 Piston, Green Spring, Out on Tower and Arm for Shock Positions, Lower Camber Link Hole on Tower, Full Droop (Unscrew Shock Ends 2 Turns), 27mm RH, 3k Diff, Next Thicker Sway Bar from Stock (Forgot what size), -1 Camber, Stock Antisquat, 3.5* Toe.
Castle MMP, Tekin 4600, 14T Pinion, Integy IP 6200 2S Batts..
HB Megabite Tires.
D8 Hara Setup:
Front: 30wt Losi, 1.3, Grey Springs, 50% Rebound, Out on Arm and Tower for Shock Positions, Middle Hole on Hub (Using Alumnium Vertical Ballstud Hubs), Middle Inside Hole on Tower, -2 Camber, 102mm Shock Lenght, 7K Diff, 2.4mm Sway Bar, 27mm RH.
Center: 7K
Rear: 30 Losi, 1.2, Blue 76mm, 100% Rebound, Out on Tower and Arm for Shock Positions, Middle Hole on Hub (Using Alumnium Vertical Ballstud Hubs), Middle Inside Hole on Tower, -2 Camber, 112mm Shock Lenght, 3K Diff, Hubs Spaced 3mm Back, 3.0mm Sway Bar, 28mm RH, Stock Antisquat, Stock Toe.
Pink Megabites with HB Red Molded Inserts.
![Wink](https://www.rctech.net/forum/classic_images/smilies/wink.gif)
SCTE Setup:
Front:
Center:
7K
Rear:
HB Megabite Tires.
D8 Hara Setup:
Center: 7K
#1178
Smiley my set up on my hara is just like urs but i run a 1.4 front piston.. Its a good setup
#1179
when you guy sway middle inside hole on tower what do you mean... they are 3 holes for camber link.. 2 on top and one below in the middle of the 2 on top.. so I'm confused when the description
#1182
#1183
i was referring to the description you gave for front setup.. thanks
#1184
wow ... I can not wait to have mine that I have been waiting a long time when I see yours ...
