Losi 8ight 2.0 split center diff mount losa4444
#16
Why couldn't they make this in plastic? Could have kept it alot cheaper.
#18
I want a weight before i shell out the $$.
#19
Chill out I was just giving my OP about the question and your getting bent out of shape about someones english, and thinking that I'm pointing out your comment without reading further.
Did you think that maybe what you said could be proven that you no longer have to do this, and you can run your carb in the correct possiton. I was just pointing this out against your post since you wanted to point out that we could all just rotate a carb and move a ball link.
If you like running your carbs that way then good I'm happy for you, but if other people want to find a correct way to run them with out having issue arise then this is what its for. If the thread said, "How do I run my carb without having it @ 90* and not bind w/o buying the new Split Center Diff Mount."
Then your input would be justified. You seem to just want to cause issues and start rants on the forum. Really it's not needed.
#22
I read it. Thing is I tried that, so I wasn't posting ahead of myself. What makes you think that I haven't tried everything else in the book before I went with the new diff mount. I rotated my carb everyway possible along with the carb ball. Any place that I put it would either be not far enough away, or would cause binding. Even if it was the slightest bind I'm not into letting it rub like that and cause shavings to come off and be sucked into the carb or burr up the inside and cause further carb sticking problems.
#23
#24
Reggie here is a link to a picture of my split mount in my truggy.
http://www.rctech.net/forum/nitro-of...ml#post6758895
#26
#29
#30
