Serpent 811 Cobra Buggy
#9572
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
Ok, so I was reading through these threads about the clutch-
I will want to run the complete losi setup- so I will need the losi clutch. bell, and collet.
i also want to run a 3/4 piece quick change engine mount, so that I can take the engine out without worrying about resetting the mesh.
Can I run the serpent quick change engine mount with the losi clutch?
Which M2C clutch can I run?
And the robinson xhard losi clutch bell should work fine with the serpent spur?
I'm 99% sure you're good with the serpent qc mount and the losi clutch setup.
#9573
it seems like every other car out there runs good on kyosho blue springs has anyone tried them on serpents, do they even fit ?
#9574
Sort of! I tried them and they make the car high in the front. I never ran them so maybe they'll settle enough. Also with the serpent collars they rub the shock body badly. I recall that chop said by using an HB adjustment nut that they fit better. A fellow racer used just the rears with good luck but he's back to white serpent springs now.
#9575
If you wannto run the losi clutch this is the he's option. There's nothing wrong with the serpet clutch though.
On the springs. Orange Durango rear and serpet orange, red, blue, or green front.
#9578
no one running the mod yet because well the things you have to do to make work might cost you a race and form what i understand it still in testing.
when you flip the arms around put the hubs long you still got grind 6mm out the arm and hub to get back farther just to make to arms the other way and forward hubs
#9579
There must be an advantage because he never runs the buggy rear shocks or shocks foward. It would be nice if Easton's real setups were posted. I have almost everything I need but I'd like to know what springs he uses.
Last week at our state race his truggy was dailed but he wouldn't share his setup with anyone
![flaming mad](https://www.rctech.net/forum/classic_images/smilies/angryfire.gif)
#9580
[QUOTE=Last week at our state race his truggy was dailed but he wouldn't share his setup with anyone
[/QUOTE]
That's not cool.....
![Confused](https://www.rctech.net/forum/classic_images/smilies/confused.gif)
#9581
Super Moderator
![](https://www.rctech.net/forum/rctechv3/special/techelite_alt1.gif)
Location: a very small town in wisconsin that is in the middle of absolutely no where
Trader Rating: 63 (100%+)
he might be working on some new things that cant be shared!!!!
#9582
Last week at our state race his truggy was dailed but he wouldn't share his setup with anyone![flaming mad](https://www.rctech.net/forum/classic_images/smilies/angryfire.gif)
![Laughing](https://www.rctech.net/forum/classic_images/smilies/laugh2.gif)
#9583
The buggy is more complicated to explain about what is different with the rear end, it has more to do with just truggy shocks and shock tower. To be honest its way more complicated than it's worth to try and copy it. There's a lot of machining and drilling. The parts he is running now will be available in the near future. At the jc clash in december I was competitive with the stock parts as well as Josh and JP with stock parts at the fl state series races. Billy could win with a shoebox.
#9585
