Serpent 811 Cobra Buggy
#7216
You guys just don't know how HARD you guys are making it...
Jus playing around on absolute hobbies... this is what is in the cart... LOL not saying im about to pull the trigger...
Serpent S811 "Cobra" 1/8 Scale Competition Buggy Kit ( Updated Radio Tray)
$539.99
Serpent 811 Aluminum Front Chassis Brace
$18.99
Serpent 811 Aluminum Rear Chassis Brace
$19.99
Serpent 811 Aluminum Rear Hub Carriers (2)
$59.99
Serpent 811 Steering Rack (Option 2)
$19.99
Serpent 811 Suspension Mount (RR RR LR 3) (7075 Alu)
$25.99
$539.99
$18.99
$19.99
$59.99
$19.99
$25.99
#7217
you go buy a xray you need castor block alum and springs and the works
you buy a losi you need a ton shit to have whatadam running
buy the serpent springs bars pistons and run it
#7218
I have a little bit to add.
About the flywheel, standard alu.
I have noticed a lot of after run oil, which I use a lot of, getting inside the flywheel.
I finally figured it out, it is going through the front bearing and then pools inside the flywheel, then seeps through the 4 holes in flywheel, which the spring holder screws go through.
This causes my engine to poorly perform as it spins the shoes around and doesnt grip the bell correctly. I saw a real lot of oil all through the clutch.
I have just started putting a DOB of high temp silicon inside the holes to seal it, Not tried it yet, but I think will be good.
Just letting y'all know in case it affects you too
#7219
Chad thanks for the help on the last purchase really appreciate your support.
#7220
Is anyone running the 8 hole con and a 10 hole con piston setup. Thinking about running this setup any feedback?
Also for the 8 hole con pistons whats a good start for oils.Will be running blue front purple back.
#7221
I'm just saying all the crap he had listed there, really isn't needed
#7222
i still think the 8 holes all around is the best set up for the car
the 10 heat up and make the car push imo
8 1.3 front blue spring 40 wt losi
8 hole 1.3 rear purple spring 32.5 wt losi
#7223
#7224
In terms of racing rc cars, I have been doing that for 15 odd years now, and always wanted Serpent to make a buggy! Every car I have raced has been a Serpent, from way back when they were 2wd 1/8th cars. I have looked at every buggy around, ran the Storm Pro, Kyosho MP777, and then started looking at the MP9, Mugen, etc., etc.! I then had a look at the 811 and that's the way we went! My son races, and he is young and really hard on the car! It is stock except for a few oil adjustments, and NOTHING has broken on this bullet! I have a pending order for a few bits, but they are tuning items, sway-bars, springs, blocks etc! No other hop-ups at present! This thing out of the box is bulletproof, handles like nothing else I have seen both on the ground and in the air! It takes patience to build it, so take your time, the end result is going to be a buggy that will make you look a lot better than you are! Just a few cents from and old timer!
$539.99
DE Racing BumpSkid (Serpent 811)
$6.35
DE Racing XD Rear Skid Plates (3) (Serpent S811)
$6.79
$18.99
Serpent 811 Aluminum Front Steering Arms (L&R)
$51.99
$19.99
$59.99
$19.99
$25.99
$539.99
$6.35
$6.79
$18.99
$51.99
$19.99
$59.99
$19.99
$25.99
#7225
$539.99
$6.35
$6.79
$18.99
$51.99
$19.99
$59.99
$19.99
$25.99
$539.99
$6.35
$6.79
$18.99
$51.99
$19.99
$59.99
$19.99
$25.99
Seriously, take that 100 bucks for the aluminum hubs and invest it in the other tuning options or just save it, the stock ones are fine. Another thing is the wear on the driveline with this car, its phenominal.
#7226
Thanks will give it a whirl
