Serpent 811 Cobra Buggy >
Old 04-09-2011, 04:18 PM
  #7111
GMS_Racing's Avatar
Trader Rating: 65 (100%+)
If i look down at mine the flat is on the top and the taper is on the bottom(toward bottom of shaft) is that right?? Also peeps out there making new throttle arms i know ya said 13/64 can i get away with 3/16?
GMS_Racing is offline
Old 04-09-2011, 04:47 PM
  #7112
jkirkwood's Avatar
Yes you want the flat part of the piston on top, taper on the bottom.
jkirkwood is offline
Old 04-09-2011, 04:53 PM
  #7113
Sean Earnest's Avatar
Looks like Billy didn't do well at Vegas
Sean Earnest is offline
Old 04-09-2011, 05:04 PM
  #7114
Trader Rating: 43 (100%+)
I run mine with the taper to the top side, cars handle great!
Brian Alderman is offline
Old 04-09-2011, 05:25 PM
  #7115
With no other changes on the rear shocks, going from the A to the B hole on the rear arm will do what to the car?
Stealth_RT is offline
Old 04-09-2011, 05:32 PM
  #7116
I built mine with the piston cut out for the washer down because I thought thats what the instructions said.
Old 04-09-2011, 05:59 PM
  #7117
Who8mySandwich's Avatar
Flat side up, don't worry about the other side.
Who8mySandwich is offline
Old 04-09-2011, 06:33 PM
  #7118
porkchop's Avatar
more traction more sidebite
4b is the best all around rear hole imo
i am still going rounds with the front end of the car
porkchop is offline
Old 04-10-2011, 07:40 AM
  #7119
ROSCOE's Avatar
Trader Rating: 130 (100%+)
Guys, I pulled my race motors with the WERKS Pro clutchs from my Hot Bodies before putting them up for sale and set one in the serpent and found that the gears where quite off (clutch bell was back). I tried the M2C mount I had as well and could get it forward more with the two hole option but almost too far forward. I havent tried a different style bell yet but was curious what anyone who is using this clutch is doing?
I have no problem with the stock clutch but would like to utilize the werks ones if I can. Thanks
ROSCOE is offline
Old 04-10-2011, 07:50 AM
  #7120
Trader Rating: 47 (98%+)
Finished body
done by off-the-wall thanks chris
http://www.rctech.net/forum/painting...-shells-3.html
wichitafc98 is offline
Old 04-10-2011, 07:55 AM
  #7121
ROSCOE's Avatar
Nice body. Is that the RB one?
ROSCOE is offline
Old 04-10-2011, 07:57 AM
  #7122
What do you mean by RB, RB motor?
It is Bitty body.
Old 04-10-2011, 08:00 AM
  #7123
ROSCOE's Avatar
It is Bitty body.
Yeah I meant body. The bitty and RB look similar I just found.
http://www.amainhobbies.com/product_...ody-Clear-S811
ROSCOE is offline
Old 04-10-2011, 08:32 AM
  #7124
hogmansp's Avatar
Trader Rating: 47 (100%+)
I will have to aggree with you on the rear 4b setup chop. I find myself always ending up with the 3b in the front. I played around with the 10 and 12 degree caster blocks yesterday and the 12's were way more consistant with the #2 rack in the sweepers and from the apex out on corners. With the #2 rack the rear is a little loose for me on 180 corners. Are your guy's bringing your epa down a little or do I need to simply control it with the wheel. Seems like the steering is a little aggressive on the tight stuff or I am aggressive with the throttle a little early on exit!
hogmansp is offline
Old 04-10-2011, 01:34 PM
  #7125
GMS_Racing's Avatar
Is anyone using the king'sheads clutch shoes..whats the diff between the 2 numbers and which one do you guys like
