Originally Posted by miket3
(Post 6170103)
mine is the red/yellow one at rochester.
I have been playing around with my setup for the BCE Chassis alot
this is what i am now running I use the same setup on my Stock chassis aswell and its dialed. but the BCE makes a massive difference Ride Height Front = 38mm Rear = 43mm Droop Front = 107mm Rear= 128mm Sway Bars Front = 2.3mm Rear = 2mm from buggy kit Springs/Shock oil/Pistons/Location Rough Track Front = black / 35wt / 55 / Middle on tower & Middle on arm Rough Track Rear = white / 32.5wt / 56 / Out on tower & Middle on arm Smooth Track Front = black / 32.5wt / 55 / Middle on tower & Middle on arm Smooth Track Rear = white / 27.5wt / 56 / Out on tower & Middle on arm Diffs Front Diff = 7k Rear Diff = 3k Center-diff= 10k Gearing/flywheel Clutch= Losi Steel flywheel, 2 carbon with gold springs 2 MaxLife with silver springs Clutchbell/spur gearing= 13/50 Toe/Antisquat Front = 5* Out Total Rear = 2.75/3 Losi adjustable toe blocks. Running all 0's in the front block set. 1's up in the forward rear block, 0's in the back rear block. Camber Front = -2 Rear = -3 Tire and Wheels AKA's, Losi/GRP's and Prolines with GRP foams Chassis, body and wing chassis = BCE Speed body = stock wing = Team Associated RC8 Electronics/Battery and Battery Placement stering Servo = Hitec 7955TG Throttle/Brake servo = Hitec 7955TG Battery = 2300mAh Intellect Lipo No regulator Electronics = Sanwa M11X Engine/Pipe/Plug/Fuel motor = RB C6BBT L2G / RB WS7III L2G Pipe = RB 2045 with 198 header / Thunder Tiger 2035 with OFNA long header Plugs = Odonnell 99T Fuel = NitroX Barmah Blend 39 30% Camber Links, Hubs front = 2 / A rear = 3 / B hubs = 1 spacer each side Track Conditions. Hard pack, large jumps, various bite |
| All times are GMT -7. It is currently 08:39 AM. |
