LIFEPO4 RX 6.4V BATTERY
#226
Hehehehe...
My ole mate cobraracing will concur with me... I have been using the 6.6v pack for a few months... it does not charge much past 6.6V and is perfectly safe to be used as a rx pack.
Lonestar you must work in safety all I hear from you is blah... blah... blah... if you want to speed and take LSD then go for it!!! it might actually open your eyes to the real world!!! perhaps you should consider a safer hobby, such as knitting or crocheting.
Here is a link for you... www.learntoknit.com/home.html
#228
#229
Hell I'd be happy with a prioritized list of anything about now. Haven't heard a word from him. Don't return emails or PM's or respond to posts here. Starting to think I should file with Paypal, get my money back and buy the Intellect ones. But I can bet I'll here " Sorry was away on business"
#231
I am truly amazed at how Angelo is able to conduct business in a viable manner, he so unprofessional, and then he goes silent, then the list of excuses it’s part of his business demeanour.
Your best bet is getting some A123 batteries (I think that’s what they’re called) I saw some on the net that have 2300 capacity. They should last at least 2 hrs minimum.
Good luck with it all. Let us know how it all goes also the excuses that should come anytime soon, keep us informed.
#232
Is Angelo=Cobraracing?
#234
Have had no dramas gettin my batteries and they fit the H9 easily. Still to do a full test to see how long they last but after 45 min only 600 mA in with ace servos.
As to him being silent I can't blame him with the crap Jesussaves and 2fst2c are going on with.
#236
This must be your 1st dealing with Angelo, you'll learn the hard way... one day... maybe ....I hope..
#238
Sorry to say but no you can't use the Pb setting on the charger to charge these batteries. You will end up destroying the battery. You can only use a charger with the Life function.
#239
6,6 volt, 1600 mAh.
Dimensions: L 84 mm, H 29 mm, W 17 mm.
Weight: 79,6 gram.
For comparison:
NiMh straight 6 volt 1300 mAh.
Dimensions: L 84 mm, H 31 mm, W 17 mm.
Weight: 123,0 gram.
#240
I have been reseaching these batteries just to get away from running a regulator. I talked to a number of racers this weekend and did'nt find a soul that's running these things ( Maybe just to new ?). But i did find good pricing @ Hobbyking and if you have a losi brand charger it will charge these.
