Hot Bodies D8 Truggy >
Like Tree10Likes
Old 02-14-2012, 11:15 AM
  #7561
rcgeezer's Avatar
Thanks guys! I think going with 2 large may be a bit overkill lol!! It seems that those filters are no longer available via Amain, so any ideas on a substitute of equal size? I like where you mounted them, makes good routing sense as I'm also not using the stock air filter...I can use that empty hole.
rcgeezer is offline
Old 02-14-2012, 01:57 PM
  #7562
ScottyM's Avatar
Trader Rating: 27 (100%+)
Kyosho has a very similar filter, but they are silver instead of Black. they do not have a dual mount , but many use 2 singles mounted nearly the same as the O'Donnell dual mount..
ScottyM is offline
Old 02-14-2012, 03:12 PM
  #7563
rcgeezer's Avatar
Doesn't the fuel line get in the way of the back side if the brake linkage where it almost hits the tank on full break? Seems like you'd have to route the line around the carb and turn the inlet a bit?
rcgeezer is offline
Old 02-14-2012, 04:13 PM
  #7564
Trader Rating: 6 (88%+)
Default Shock ends
Hey guys what's the part number for the silver balls that go in the shock ends?
Drip is offline
Old 02-14-2012, 05:15 PM
  #7565
Anyone with pics of Tys reciver battery setup for buggy adn truggy? Thanks !!!
Chaney is offline
Old 02-14-2012, 05:56 PM
  #7566
DK McGee's Avatar
Trader Rating: 36 (97%+)
I ve been looking at some pics of buggys/truggys and noticed some using fuel tubing on both brake pulls where the stock springs go. Would this be used to not have as aggressive braking issues ?
Dave
DK McGee is offline
Old 02-14-2012, 07:12 PM
  #7567
no probs yet
metalbart is offline
Old 02-14-2012, 09:30 PM
  #7568
Dave
the fuel line is stiffer than the spring. So if you want the pressure to apply better use fuel line but you should have the back breaks slightly tighter than the front so the back locks up first. It makes it easier to swing the rear around the turns better. but that just me but a lot of guy do it that way. It seem to have more control then with the fuel line. I would cut some the same size of the springs and give it a try you might have to adjuste it some but it should work out better. Good luck.
imrob is offline
Old 02-14-2012, 09:44 PM
  #7569
DK McGee's Avatar
Thanks Imrob.............. great idea
DK McGee is offline
Old 02-15-2012, 09:31 AM
  #7570
Precision1's Avatar
Trader Rating: 51 (100%+)
Questions??
If using fuel line to replace the spring on the brakes you can actually cut it half the size or less of the spring length. This also allows you to shorten the rods and keeps them much farther from the tank.
Now for the question:
Off power steering is insane, turns on a dime.
On power is horrible, turns on a man hole. Doesn't matter if full throttle or 1/4 throttle.
Current diffs are 7/7/3, shocks 35 front/rear, sway bars 2.3 front, 2.5 rear.
I would like some more power steering. Looking through this thread I see these suggestions:
-Diffs to 5/10/3
-Move rear hubs back
-Heavier oil in front shocks
-Check front sway bar, check servo saver spring
Am I heading in the right way? I was going to try them in order listed.
Thanks!
Precision1 is offline
Old 02-15-2012, 09:44 AM
  #7571
Suspended
Trader Rating: 17 (95%+)
-Diffs to 5/10/3
Thanks!
More Steering Into the Corner:...............
Thinner oil in front diff
Less caster
Stand up front shocks on tower
Front upper link down on tower
Short ackermann plate
Steering link back on Ackermann plate
Thinner rear swaybar
Lean rear shocks down on tower
More Steering Mid-to-Exit of the Corner and On-Power:...................
Thicker oil in Front diff
More caster
Lean front shocks down on tower
Thicker rear swaybar
Stand up rear shocks on tower
D-MAIN is offline
Old 02-15-2012, 02:45 PM
  #7572
ScottyM's Avatar
-Diffs to 5/10/3
Thanks!
Less caster
More caster
Make one of the above changes at a time.. DO not change all of that or you will be so loose you can't control it..
I suggest running the Smiley Set Up. Search this thread for it, it has been posted a few times..
ScottyM is offline
Old 02-15-2012, 05:10 PM
  #7573
DK McGee's Avatar
good info.............. " I suggest running the Smiley Set Up" Smiley runs buggy, RU suggesting run a buggy setup on a Truggy? on another note WHERE DID I GO WRONG HERE !!!! I called proline and they said the body will work if i drill the tower for the front mounts well i did and this is what im getting ! the only way i have clearance of top shocks . Thanks in advance
Attached Thumbnails Hot Bodies D8 Truggy-100_2070-600-x-450-.jpg   Hot Bodies D8 Truggy-100_2071-600-x-450-.jpg   Hot Bodies D8 Truggy-100_2072-600-x-450-.jpg   Hot Bodies D8 Truggy-100_2073-600-x-450-.jpg
DK McGee is offline
Old 02-15-2012, 05:20 PM
  #7574
LOW ET's Avatar
Trader Rating: 109 (100%+)
you have the wrong body mounts. you need losi 8t 2.0 mounts # losa4433
http://www.amainhobbies.com/product_...ount-Set-8T-20
LOW ET is offline
Old 02-15-2012, 05:25 PM
  #7575
Suspended
you could have just moved your body mounts up and use one screw, the small plastic pin on mount rests on top of the shock tower, then you would have not had to cut body like that.
D-MAIN is offline
