8T 2.0
Old 05-17-2012 | 01:03 PM
  #14536
Maxxed-out's Avatar
Originally Posted by ironzgti35
How do I get the slop out of my wheels? I own 3 other Losi's and now they get loose but this T i just picked up has more than i've ever seen. The wheel will wobble about 1/4inch side to side. Looks horrible rolling at slow speed of free wheeling in the air. I've replaced the bearings, hexes, hubs, axles, linkages and its still there. Even tried different rims to see if the wheel hexes were out.
I must have overlooked something, what else gets loose and worn that would create this much slop.
http://www.amainhobbies.com/product_...mm-Shim-Set-20
You can shim between outside bearing and hex to get rid of a little slop. I think the 8mm shims is what you need, cant remember off top of my head. I use shims on my buggy.
Maxxed-out is offline
Old 05-17-2012 | 01:45 PM
  #14537
token's Avatar
My truck is dialed IMO. I have maybe 3.4 gallons on it at the moment and I still have play. I have tried to shim it up, and it was horrible. The losi has play and IMO runs WAY better with the play than with out. I believe its made to flex and have a bit of play.
token is offline
Old 05-17-2012 | 02:04 PM
  #14538
guss2009's Avatar
Originally Posted by jnorwood_losi
Does anyone have pics of the steering horn with the bearing mod for the Gen III and what kind of bearings to use ect.. (any info and help)
Adam Drake Modification to the TLR Gen 3 Radio Tray
http://www.youtube.com/watch?v=Fp8gI...eature=g-all-u
guss2009 is offline
Old 05-17-2012 | 02:31 PM
  #14539
jnorwood_losi's Avatar
COOL, nice that he did the video! I might give it a try!
jnorwood_losi is offline
Old 05-17-2012 | 02:34 PM
  #14540
token's Avatar
It takes like 3 mins for real.. I didnt even remove the horn from the tray... whole set up cost me 6 bucks..
token is offline
Old 05-17-2012 | 02:45 PM
  #14541
rider313's Avatar
I also threw bearings on the break linkage to. Avid has the bearings for $1 a peice and not the $23 for 4 like losi wants.
rider313 is offline
Old 05-17-2012 | 08:41 PM
  #14542
Wheels are going all the way on each side, the pipe wire doesnt touch and i have the old blocks. What is about the knuckle mod?
Big_one is offline
Old 05-18-2012 | 05:19 AM
  #14543
Maxxed-out's Avatar
Did you check the servo saver? If the wheels aren't touching the ground they will go all the way but when you put in on the track and there is weight on the wheels the servo saver will flex because its too loose.
I had the same symptoms you are having and I was about to go buy a new servo but I was told to check the ss and that was the problem. I have the stock blocks and am running the same servo as you and my truck turns awesome.
Old 05-18-2012 | 07:46 AM
  #14544
+1
I used 3 Avid bearings on each car. Throttle is waaaay better now. With all that slop it was a guessing game when I pulled the trigger.
AZTman is offline
Old 05-18-2012 | 10:45 AM
  #14545
Jerm13's Avatar
You take a dremal and mill down where the knuckle contacts the caster block. You only need to do 2 or 3 mm at most. Any more than that and your arms start to hit the wheels and scrub speed when fully locked.
I took a silver sharpie marker and marked it. After I ground the first one, I mesured it and tried to get the other side exactly the same.
Here is a pic. The left is modded and the right is the stock one.
Jerm13 is offline
Old 05-18-2012 | 05:00 PM
  #14546
vito's Avatar
http://www.amainhobbies.com/product_...o-High-Voltage
just pick this up for my t/b one
vito is offline
Old 05-18-2012 | 05:59 PM
  #14547
BMenard17's Avatar
Mind you I dont have my buggy in front of me but is this mod necessary with aluminum?
BMenard17 is offline
Old 05-18-2012 | 06:31 PM
  #14548
Jerm13's Avatar
Its not nessasary. But I know a lot of people that run the Inclined Spindles do this to gain back most of the steering you loose. Mose so in Truggy than in Buggy.
I still run the plactics and did it just to see if would help at a couple of the tighter tracks around here. It made a world of difference. I can stand in one spot and the truck will circle me just bairly missing my feel all the way around. The radius is much tighter now. It gives you more throw which helps for more steering on and off throttle.
Jerm13 is offline
Old 05-18-2012 | 06:33 PM
  #14549
Jerm13's Avatar
Originally Posted by vito
That looks like a good one. You could even use that same one for your steering. Around 300 oz/in is really all you need even if the track is high bite.
Jerm13 is offline
Old 05-18-2012 | 09:26 PM
  #14550
vito's Avatar
my dad gave me a 100 bill for my brithday pick up a new t/b servo from a main
vito is offline
