8T 2.0
Old 11-05-2010 | 02:29 PM
  #9991
rider313's Avatar
I heard the stock plastic spindles could also be ground down? has anyone done this?
rider313 is offline
Old 11-05-2010 | 02:31 PM
  #9992
MikeFriery's Avatar
i would suggest doing the caster block, not the spindle.
It works fine on the plastic, with no noticeable loss to durability.
I would use a carbide cutter and some calipers
MikeFriery is offline
Old 11-05-2010 | 02:41 PM
  #9993
rider313's Avatar
thanks for the insight. got bolth of those in my one of my tool boxes.
rider313 is offline
Old 11-05-2010 | 03:14 PM
  #9994
dnebout's Avatar
I have with no problems. Never measured how much I took off or what is left. I just hit them a mil or 2.
dnebout is offline
Old 11-05-2010 | 03:16 PM
  #9995
losi_racer's Avatar
same with me. Billy Fisher showed me this and since then ive been doing it. i didnt do it on my new truggy yet tho and i can notice a difference
losi_racer is offline
Old 11-05-2010 | 05:53 PM
  #9996
Bman's 3XNT's Avatar
Can I see some pics please? I would like to do this, but would like to see what so I don't screw anything up.........Thanks!
Bman's 3XNT is offline
Old 11-05-2010 | 06:27 PM
  #9997
sluggo_sx8's Avatar
pics of the plastic units modded would be nice please!
sluggo_sx8 is offline
Old 11-07-2010 | 11:05 AM
  #9998
dnebout's Avatar
What I did wouldn't come out in a picture, because when you take away black material from the spindle, you're left with the remaining black material. Since it's black to begin with and you're left with black after grinding, it won't photograph well enough to see what has been removed. Just do it this way...look to see where the spindle hits the spindle carrier at full steering lock and remove just enough material off of the spindle so it doesn't hit the carrier at full lock.
dnebout is offline
Old 11-07-2010 | 01:33 PM
  #9999
sluggo_sx8's Avatar
ok cool thanks!
Old 11-07-2010 | 02:50 PM
  #10000
losi_racer's Avatar
x2
just take a little away.
Old 11-07-2010 | 05:34 PM
  #10001
pballer2777's Avatar
just was wondering how often do u guys change the brake discs? how do u know when its time to change them?
pballer2777 is offline
Old 11-08-2010 | 09:27 AM
  #10002
juggaloracer198's Avatar
Questions??
rear diff......so i stripped the pinion gear and the ring gear....just wondering if there should be any play on the pinion after installing driveshaft
juggaloracer198 is offline
Old 11-08-2010 | 02:17 PM
  #10003
Integra's Avatar
Pinion needs to be tight against the bearings along with the pinion output on the case, So No play what so ever....Dont Crush it together but no play.
Integra is offline
Old 11-08-2010 | 03:13 PM
  #10004
Led Finger's Avatar
Default shock springs
Hey guys just picked up a 8 t 2.0 roller, wondering which shock springs to use.. my track is smooth and tight, just a few jumps... nothing crazy
Led Finger is offline
Old 11-08-2010 | 03:54 PM
  #10005
recrutr911's Avatar
How do you get it tight? Do you put the shaft coupler on the pinion shaft before you assemble the diff case? Mine always has a little forward play in it.....
recrutr911 is offline
