8T 2.0
Old 10-27-2010, 09:19 PM
  #9886
losi_racer's Avatar
Trader Rating: 25 (100%+)
my new paint scheme
losi_racer is offline
Old 10-27-2010, 09:54 PM
  #9887
recrutr911's Avatar
Default Paint Scheme
Looks like the same paint job you had last month
recrutr911 is offline
Old 10-28-2010, 02:34 AM
  #9888
TIX
TIX's Avatar
Trader Rating: 17 (100%+)
try running a lower front ride height and 3-B on the front camber links
also make sure your front wheels are not locking when you break
i use that and get heaps more off power steering
if you use the 3-B camber link just check that the ball end doesnt rub on the top of the carriers near the king pin. sometimes you have to file a little bit off the inside edge of the carriers
TIX is offline
Old 10-28-2010, 07:55 AM
  #9889
Frank L's Avatar
Trader Rating: 148 (100%+)
Anything for the dreaded on power push?
Frank L is offline
Old 10-28-2010, 11:05 AM
  #9890
losi_racer's Avatar
Ha ha to locals it isn't new well it was at byrons
Old 10-28-2010, 12:20 PM
  #9891
token's Avatar
Question: how long do you guys that pay for your stuff use your fuel tank for?
token is offline
Old 10-28-2010, 12:24 PM
  #9892
Frank L's Avatar
I usually go until the springs wear out or I get lazy and dont want to replace the line inside I would say 4-6 months is avg racing 2-3x per month.
Frank L is offline
Old 10-28-2010, 12:26 PM
  #9893
token's Avatar
What about just changing the lid? Is that like the thing to do?
token is offline
Old 10-28-2010, 01:19 PM
  #9894
mblgjr's Avatar
Trader Rating: 86 (100%+)
Originally Posted by juggaloracer198
i want more off power steering
Increase rear brake bias/decrease front brake
Increase negative camber in the rear.
Increase front toe (it will let you come in faster, brake a touch later and "flip" the truck around the corner).
Different tires front/rear (AKA Cityblock front, Ibeam rear).
Trim rear wing lip.
There's a lot more you can do as well; but the tires and rear brake bias are two major points that the truck will react to.
mblgjr is offline
Old 10-28-2010, 01:40 PM
  #9895
sluggo_sx8's Avatar
Originally Posted by losi_racer
my new paint scheme
nice would be great to see a better pic though
sluggo_sx8 is offline
Old 10-28-2010, 03:02 PM
  #9896
JAMMINKRAZY's Avatar
I replace mine quite often. Usually every month or so depending on how much I'm running. In other words that's during the summer. Winter time I don't run much nitro. I usually go through a couple during the summer. Not sure that's necessary, but one of my biggest pet peeves is air leaks. I don't like the idea of just changing the lid. Tanks are cheap enough to replace every couple months.
JAMMINKRAZY is offline
Old 10-28-2010, 03:35 PM
  #9897
builtb16a's Avatar
I replace my tank when it breaks. I change my fuel line when I notice it leaking out of the hose inlet. I've yet to replace the spring or rebuild a tank. If I don't have to throw $20 down the drain I avoid that upkeep cost.
builtb16a is offline
Old 10-28-2010, 04:02 PM
  #9898
Frank L's Avatar
It's a pain in the ass and I don't need any more of those on my bench.
Frank L is offline
Old 10-28-2010, 05:16 PM
  #9899
losi_racer's Avatar
Im with you. 15 bucks is worth putting into my car roughly every month or two for piece of mind. i dont have to worry about fuel link going old or the springs going weak
Old 10-28-2010, 05:49 PM
  #9900
rotarynut's Avatar
Trader Rating: 30 (100%+)
Questions?? brake discs
question guys, will the brake rotors from a 1.0 work on a 2.0, I'm wanna get the xtreme racing carbon fiber discs http://www.xtremercracing.com/Store_...ue&SnipID=6135 but they only show what looks like they are for the 1.0 . I have a set of these on my Cen Matrix R2 they work really great,no fade whatsoever. does the smaller rotor take a different size brake pad? I have the "improved" rotors from Losi but IMO they aren't all that good. I was also looking at the rotors from Avid, does anybody have any experience with those? thanks for any info.
rotarynut is offline
