8T 2.0
#9166
#9167
Yeah I've run some losi linkages for a very long time before without an issue. I do like to change them occasionally to keep them fresh, but I can't say I've ever noticed a difference between a worn out linkage and a fresh one on the track. Its kinda a non-issue to me, but I still like to change them occasionally.
#9170
Nothing will work on the stock losi axles. There's nothing for the boot to grab onto. Just run them dry and keep them as clean as possible. Going on 10+ months of racing on the same set of CVD's here. The only one that's been replaced is the front center shaft. Others are about due for replacing but have lasted remarkably well. No boots and no grease.
#9171
i dont know about running them dry i use a little bit of red mobil grease and the mud guards do help than if i dint have them on yikes.
yea i was just thinking that the axle would have to have something for it to grab on to.
#9172
My opinion... Grease only attracts dirt if you don't have some type of boot to keep it clean. Dirt is what wears CVD's out. Keep them clean(grease free in this case) and they will live longer.
That's just my opinion and I could be wrong, but I'm usually not.
#9173
i agree, ive never greased my cvds
#9174
they get kind of dirty no much though there still a little smooth.
so there are still smooth running them dry ?
#9176
-Howard
#9177
They were both decent impacts. Both times I got a little out of shape on the approach to a fairly large triple, which resulted in my truggy coming down hard on the front right wheel. Something was going to give, I was just surprised the M2C pins snapped instead of bending like the Losi pins. I've crashed much harder on the losi pins and never had one snap. Things like catching a hole in the wall / spike in the pipe at WOT... lol
-Howard
-Howard
somewhat justified then i guess, Ive pulled out bend M2C and losi pins in the past and feel they are Very much on par with each other as far as durability goes.
#9179
Not sure if this correct but after each race to keep my CVD clean I uses a spray non contact lube shoot in cup to clear out all dust. It works very well it keeps its clean and lubed with no attraction.
#9180
Found these on amain. seems like a simple idea, but not owning an 8ight t 2.0 yet so i have no refernce. sure somebody here with know how will give some proper insight here.
king headz dust seals
