8T 2.0
Old 08-31-2010 | 09:53 PM
  #9001
tc5 man's Avatar
Originally Posted by builtb16a
no modification to the koyosho boots 1 bit. the rear shocks are a bit snug.. thats why i showed both a front and a rear. but they do fit without stretching and tearing. they're good fit for both front and rear.. a dead ringer to me, rather than the f/r thin losi boots.
and every other run.. thats crazy. im by far a pro, and can actually "feel" the difference, so im just happy my boots aren't torn jacking up my shock pins, and getting my oil all mucky.
anyways, just thought ide share the info.
cool i might, have to cut them a bit since im running the 1.0 t shocks on my eight -t no big deal though.
tc5 man is offline
Old 08-31-2010 | 11:00 PM
  #9002
Sein's Avatar
Thanks for sharing!! I know I am getting those next time.
Sein is offline
Old 08-31-2010 | 11:59 PM
  #9003
kayl's Avatar
Done a few upgrade on my losi
New braces front and rear, did the diff oils while it was apart, 7k, 7k,5k rear
also put new pipe in RE10, man it has made a massive difference, ripes the grass up when it takes off. WIll install the turbo head next to see the difference again, can't wait.
kayl is offline
Old 09-01-2010 | 12:51 AM
  #9004
tomdex's Avatar
also put new pipe in RE10, man it has made a massive difference, ripes the grass up when it takes off. WIll install the turbo plug next to see the difference again, caint wait.
Kayl, nice job! On the grass, I'd try 10F 15C 5R oils mate, thats what i run in the Losi Truck In the Truck you need heavy oils on a high traction track, such as grass.
Also, try the softer purple rear springs if you have them. I notice you still have the standard white ones on.
tomdex is offline
Old 09-01-2010 | 03:21 AM
  #9005
kayl's Avatar
will try those ratios hey. Ill have to order some different springs, have been changing the shock oils but havnt bother with springs yet, not sure what to try
Have you changed the front springs?
kayl is offline
Old 09-01-2010 | 04:44 AM
  #9006
JAMMINKRAZY's Avatar
Stock springs(and the ones he has on there) are grey and are softer than purple. If you're looking for a softer spring, purple is not the answer. Purple is actually the stiffest spring losi sells.
JAMMINKRAZY is offline
Old 09-01-2010 | 07:25 AM
  #9007
Integra's Avatar
I was just gonna say....No white on that truck.
Integra is offline
Old 09-01-2010 | 09:04 AM
  #9008
Toiffel's Avatar
Originally Posted by Toiffel
Front Hinge Pin Braces are ovaled out, that is why my dog bone was popping out!!!! Thanks guys...
nope, replaced the braces, hinge pins, arms, dog bone, bearings, hubs, carriers, and nothing, the right side is still popping out, the only thing I haven't tried is to shim the front diff so its pushed a little to the right side..
Anyone has or is shimming the front diff??
Toiffel is offline
Old 09-01-2010 | 09:41 AM
  #9009
Integra's Avatar
I have a couple thin's up front on both sides...Im still baffled as to why this issue is present...Over the year's its happened to a couple guys and the results never seem to be the exact same.....the guys also did what you have done in regards to throwing new parts at it Till there all Brand new and the issue is still there.
Im gonna see if i can get Drake to stop by here and give a read over your posts and see what his take on it is....I dont know if he's ever experienced this but i would be interested to hear his through's on why it could/might happen.
Integra is offline
Old 09-01-2010 | 09:49 AM
  #9010
Toiffel's Avatar
Thanks, I'll post some pics tonight, see if that helps.......I'm picking up new diff housing and case tonight.....
Toiffel is offline
Old 09-01-2010 | 09:57 AM
  #9011
bigjayjay1's Avatar
Thats weird thats prettty much the whole assembly other than diff case.
bigjayjay1 is offline
Old 09-01-2010 | 09:59 AM
  #9012
pyromania's Avatar
Dose the dog bone pop out while you're running it normally or after a big crash?
pyromania is offline
Old 09-01-2010 | 10:04 AM
  #9013
Toiffel's Avatar
Running normally, I first noticed it was coming out while warming my truck up on the starter box, the front right tire was wabling very bad like it was off balance, and after further inspection I noticed that the bone was about to pop out....
Toiffel is offline
Old 09-01-2010 | 10:32 AM
  #9014
pyromania's Avatar
Have you checked the arms to see if they are warped?
Old 09-01-2010 | 10:47 AM
  #9015
Toiffel's Avatar
So far I have replaced with new parts:
Hinge pin braces inner and outer
Hinge pins
Arms
Bearings
Hub Carrier
Spindle
Dog bone
Outdrive cups
Tonight:
Diff case
Diff Housing
and going to shim the diff
Toiffel is offline
