8T 2.0
Old 08-29-2010 | 06:23 PM
  #8956
pyromania's Avatar
Originally Posted by JAMMINKRAZY
I used to run skids all the time too. Then I stopped running them and everything felt better. There was one layout we had that had a lot of sharp edges on jumps and I noticed the back end being kicked up. Took the skid off and all of my problems went away. I've yet to put one back on since. The truck just feels better without the skid on there. That was my experience anyway. I used to swear by DE skids... Not anymore. Still lovin my bumpskids though.
What gen skids were you running? The old DE's used to crunch up and lip causing the skids to catch on jumps.
pyromania is offline
Old 08-29-2010 | 06:27 PM
  #8957
JAMMINKRAZY's Avatar
I've used all of them. Was using the XD's at the time.
JAMMINKRAZY is offline
Old 08-29-2010 | 06:33 PM
  #8958
THE PHILLY JYNX's Avatar
Are you guys running single rubber shield,double rubber shield or no shield on the exhaust bearing and just allowing the oil from the exhaust to lubricate them?
THE PHILLY JYNX is offline
  #8959
pyromania's Avatar
Weird. I guess the sharp angle of some jumps make the skids catch. If I ever encounter the donkey kick problem, I'll check my skids.
Old 08-29-2010 | 06:35 PM
  #8960
tc5 man's Avatar
come on man you can pm about this muffler bearing.
tc5 man is offline
Old 08-29-2010 | 06:39 PM
  #8961
pyromania's Avatar
Sorry bro, the mods already told us not to be PMing each other that kind of info. We're in big enough trouble as we speak.
Old 08-29-2010 | 06:48 PM
  #8962
tc5 man's Avatar
well i dont see what the big deal is but whatever lol.
tc5 man is offline
Old 08-29-2010 | 06:50 PM
  #8963
I prefer the non shielded Muffler Bearing. It allows for a smoother feel with higher RPM's. They seem to last better too with more lubrication getting to them.
Too true. If you have to ask, you'll never know.
Old 08-29-2010 | 06:52 PM
  #8964
l3asher's Avatar
Are you by chance running a rear skid plate?
Frank,
How long ago did you redo the shocks? I run skids all the time and I've never noticed it kick-up because of the skids.
Running the skids, I don't think that is the problem. The shocks have about a half gallon on them. Would going down in shock help with the kick up per say?
l3asher is offline
Old 08-29-2010 | 06:53 PM
  #8965
pyromania's Avatar
Are you using a full ceramic bearing? The top end is just insane with those.
Old 08-29-2010 | 06:55 PM
  #8966
You gotta have the full ceramic.
Old 08-29-2010 | 06:57 PM
  #8967
pyromania's Avatar
To quickly check take the skids off for a lap or two. If you're still donkey kicking try raising you ride height a bit.
Old 08-29-2010 | 07:12 PM
  #8968
teamlosi906's Avatar
You think so. Intercooled is the way to go.Bearings last forever. I had a ceramic bearing blow right thru my new muffler.
teamlosi906 is offline
Old 08-29-2010 | 08:02 PM
  #8969
l3asher's Avatar
Let me rephrase the question. Will lowering my shock oil in the rear help with the rear end kicking up on jumps?
l3asher is offline
Old 08-29-2010 | 08:35 PM
  #8970
Jammin57's Avatar
No it will make it worse, the chassis slapping is caused by you're truck being too low or being to soft in the rear add some more shock preload and it should stop
Jammin57 is offline
